the 7* is partly for packaging but also to do with cylinderhead oil drain, the manta sump is designed for the 7* but not for fwd packaging so guess what you want (the manta sump has it's lower surface horizontal with the engine / gasket surface @ an angle to allow the exhaust side to lean lower)
so sump gasket face horizontal and the 'wings' will be at an angle with the inlet side lower.....
^^ maybe not the best description
imho the manta sump is good for a manta, sorta fits a Chevette but in a mk1 or 2 escort its nearly useless due to its shape - the engine wants to sit in the bulkhead
SBD had sump / pickup and 'windage-tray' modification info pages on their website (~15+ years ago when I last used a manta sump
Rich.
