Are there any HT1E dyno results?
what is your advice???
Re: Are there any HT1E dyno results?
A bit more info would help people advise. What you going to use the car for, what’s your goals etc…
It’s going to be fitted on a Mk3 Cortina with HD Type 9 and a Gripper 4,11 diff
the car is going to be used for fun on the road and maybe some trackdays
twin 45s with very long inlet manifold and long trumpets, ignition is Bestek distributor with MSD 6AL2
engine is equipped with 84mm stroke, steel rods and 93mm Eisner forged pistons
I see that nobody replies, has anybody ever tried the HT1E camshaft? What are the pros / cons? If the engine has greater capacity (more than 2.000cc) works better?
http://www.turbosport.co.uk/showthread.php?t=1848063
http://www.turbosport.co.uk/showthread.php?t=1848638
The forum is fairly quiet these days. Better off using the search function as there is plenty good info to be found.
I’ve put a couple of links above that are worth a read and also worth checking Grahams YouTube videos under Penguin Motors
From my understanding the larger capacity brings the power back down the rev range a little. But how much I'm not really sure.
With that combo I would think you should see over 200bhp, but it all depends on a lot of other variables too.
there are plenty of dyno sheets on a HT1 or similar out there HT1E isnt going to be dramatically different
I have read from another post that the HT1 and HT1E are almost identical but the HT1E makes peak (same HP) and (10 lbft Torque) some rpms earlier.
I am trying to use Search and it doesnt return any results
