Stripping down the engine after having it sat in the car for what seems like years (actually, it *is* years) to mock up the work needed to fit it. We're now ready to paint the engine bay and interior and finally fit it for *good*.
Anyway, as we were degreasing it and generally taking all the parts off, we noticed that the timing wasn't lining up. With the crank set to the TDC mark, the exhaust cam was set correctly (arrow pointing towards the inlet) but the inlet cam and distributor/oil pump drive wasn't lined up either.
The inlet cam was one full tooth out (retarded compared to exhaust), we've corrected it and the distributor gear now (again, one tooth out), so that all the timing marks line up.... Hand turning the crank it's turning over fine now (though it did before!), and with all 3 marks on TDC it's ready to fire on no. 1 and rocking on no. 4 so it looks to be set spot on.
But my question is, could it have run with the inlet one tooth back? Would there be any reason to do this deliberately?
