Im in the stage of converting my Weber carbed Cosworth N/A to throttle bodies.
Im going to use an Omex 600 ECU.
The question is when all the wiring and plumbing is done can I stick with the dissy set up for intial start-up.
The reason is Im new at the EFi stuff and thought if I run fuel only via the ECU first if it doesnt run I will know its not an Ignition issue, therefore easier to fault find.
Then when and if it runs I can connect the ignition side of things via the ECU.
So...is this possible, is it a daft idea?
