Results 1 to 4 of 4
Thread: advice needed please
    Lt. Daaaannnnn Decade Plus User thepintoman's Avatar
    Dec 2006
    dartford
    3,144
    im looking for some advice
    ive been thinking of running a pair of 44idf's on my redtop, is there anyone with any info about using idf's on a 16v redtop thanks dan
    25,132
    313
    Re: advice needed please
    if you already have the carbs the only real issue i can see is finding a suitable inlet manifold,
    although IDFs being rarer than sidedrafts you could probably sell them for enough to buy a set of sidedrafts and an inlet manifold filters etc to fit the xe
    Dec 2006
    dartford
    3,144
    bogg bros will do a manifold so that shouldnt be a problem, im thinking the 44's may flow better as they will be up in the clear air rather than tucked down the side of the engine like side drafts
    25,132
    313
    no they wont flow more air than the sidedrafts as they are obviously 44mm not 45 or bigger like the sidedrafts, although otherwise very similar but also having a 90 degree turn in an inlet manifold doesnt exactly help airflow, i cant see it making much difference where in the engine bay the carbs are, you might even find you loose power with them higher up because they are drawing more hot air heat from the engine rising rather than cooler air from through the grill.
    as i said i dont suppose it will make much difference either way, but i very much doubt you will get more power from you downdrafts
Similar Threads
  1. advice needed please
    By kirk honda in forum General Car Banter
    Last Post: 07-01-2008, 04:17
  2. advice needed
    By kev16v in forum General Car Banter
    Last Post: 08-07-2005, 13:28
  3. advice needed
    By andy in forum General Car Banter
    Last Post: 18-05-2004, 09:49
