Hi All,
I've aquired a Catcams 228 0312 cam.
Currently doing a testfit in my spare engine, and have some geometry and clearance questions.
This cam gives around 13mm lift, with 3.85mm claimed at TDC.
It also has a reduced base circle to archieve this.
This means I've got to wind out the ball studs to get the spec'd clearance of 0.25mm.
What's the minimum engagement of the studs in the head before I should look at getting extended studs?
Currently It looks like they've got about 8mm of thread in the head.
Second question is regarding clearance from the valves to the piston around TDC.
What clearance between the valve and head should I maintain as the minimum?
I imagine there's some expansion happening as the engine heats up and the rods stretch under high revs, and i'd rather not have them meet
engine in question is a 205.
