Originally Posted by
fingersnfumbs The car is a Mk2 Escort with a Cosworth N/A.
Runniing Weber DCOE's.
Its currently running a mechanical pump which I think is on its limit. Engine is around 185hp.
I plan on fitting an Electric fuel pump.
A few questions:
Could I fit it under the car below the standard tank?
I ssume I will need a pressure regulator?
Can it be fitted next to the pump?
Do I need a return line to tank?
Obviously need a filter, can that be under car?
Could I use my existing fuel line if Press reg is under car by tank?
Finally, what pump is best?
