Results 1 to 14 of 14
Thread: cosworth will not start when hot
    Jul 2004
    somerset
    84
    Hi has anyone got any ideas on my 3dr cossy . i got it back from having coilovers and gpa speedlines fitted .the fuel was very low but i got it to petrol station and filled it up, drove it home about 3 miles switch it off went to restart it and it just wound over but would not start . so i pushed it in the garage put it on charge and in the morning it started no problem . now when i start it from cold it starts fine , go for a drive and its fine . I go about 5 miles come home park it on the drive switch it off and try to restart and it just winds over on the key , i leave it 5 mins and it will start . if anybody has any ideas i would be greatfull thanks rcmex
    Mechanic flannigan's Avatar
    Dec 2003
    surrey
    665
    Re: cosworth will not start when hot
    ecu control relay or fuel pump reylay
    Jul 2004
    somerset
    84
    Hi flannigan thanks for your help again . what colour ar they and are they on the loom by the ecu thanks rcmex
    Mechanic escort greg's Avatar
    Dec 2005
    underground
    551
    the fuel pump relay is yellow and is below the ecu cover underneath the dashboard hope that helps.
    cirencester
    14
    could be the ect sensor at the back of the head on the right [blue sensor] tells ecu when engine hot or cold
    Bodger DaveHenshall's Avatar
    Sep 2003
    Cheshire
    120
    or just a dud battery like ive just had....
    when u go to click 2 (before u crank it) can you hear the fuel pump prime up and the idle valve start clicking....?
    what voltage is the battery when its sat not running and what is it when it is running?
    Its a Police State - Lets Emigrate....
    The Dark side...
    Jul 2004
    somerset
    84
    Hi thanks for the replys . Dave my battery does go flat in a week . just tryed the car again when i turn key to p2 it clicks but no buzz from feul pump but it starts and runs fine . If i leave it running untill the fans cut in and turn it off it will not start , i leave it 10 mins and it will start so im a bit lost on what it is any more help would be good thanks rcmex
    Pit Crew Decade Plus User nickmk11's Avatar
    Sep 2004
    uk kent
    51
    1,143
    sounds like a bit of heat soak try phase sensor ,ign amp then coil ,crank sensor ,i have had a few where it is the phase sensor doing this
    MOBILE REMAPPING KENT
    Spam Man mk1 gaz's Avatar
    Jun 2005
    Sarrrrrrrrrf London
    5,408
    fuel pressure dropping off
    Clint's Avatar
    Jul 2001
    937,144
    Can you hear the pump running when it wont start? if not try bridging the relay and see if it runs then.
    You may have introduced some dirt from the tank into the pump if you run it really low if the pump was tired anyway it may of sent it over the top.
    if the pump is seized when hot they normally make a thud when you turn the key, you might not hear it in the car so get a friend to listen or hold it.
    Pull a plug and see if you have a spark whan it dosnt run.
    If it was a magor sensor the ECU light would come on.
    Fill out your profile so we can see where you live
    UK Mahle and Reinz Distributor - 3J Driveline Dealer - Corbeau Seat Dealer
    [B]Engine Parts for most makes, all Ford parts kept in stock, Pinto, Xflow, YB, V4, V6, Zetec, Dratec, Wiring Looms Plugs, Plug Kits and Loom Products, Head Refurbishment and Porting, Engine Rebuilding Services.
    Jul 2004
    somerset
    84
    thanks for the replys everyone i think fuel pump and filter may be the cause . The pump does buzz when it will not start , but the strange thing is it does not buzz when it is cold but it will start . Yesterday i drove the car about 10 miles and at a roundabout it cut out , after half an hour it started ran fine for 6 to8 miles went to pull away from another roundabout and it done it again . if this helps as its a bit embarrising sat there trying to start it . clint i will fill out my profile thanks for the help rcmex
    Spanner Monkey Ianbavs's Avatar
    Oct 2015
    347
    Hi did u fix problem with a pump swop cheers
    mines doing the same :-)
    Oct 2015
    347
    Ran ok for 25 yrs though
    Oct 2015
    347
    Phase sensor inside distributor fella
    I had the same
    Went over to wasted spark setup in the end just for more reliability
  1. cosworth and rs parts big clear out
    By KAIBO in forum Parts For Sale
    Last Post: 10-05-2009, 20:01
  2. Big clearout of parts more listed
    Last Post: 13-09-2005, 06:37
  3. NA cossie engine won?t start!
    By IanD in forum Cosworth Installations
    Last Post: 03-01-2005, 13:48
  4. Cosworth..noisy cold start
    By GavinFitz in forum The Technical Section
    Last Post: 05-05-2003, 13:35
