Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 121 to 160 of 176
Thread: Type 9 gearbox tutorial
  1. #121
    Pit Crew Decade Plus User bortaf's Avatar
    May 2004
    london
    1,021
    15
    Re: Type 9 gearbox tutorial
    What's the outer size? burtons do 3 differant spigots for the cologne
    19X12.7
    21X12.7
    21X15
  2. #122
    Tyre Kicker pilot78's Avatar
    May 2010
    Hungary
    Hi there !
    I see that here is everybody has experience with type9 gearboxes. I would like to know the input shaft's bearing number...i mean the numbers on that bearing witch is the firs bearing on the input shaft. It is a ball bearing with ring on its outer side. already found it on Ebay but it would be better to know the number.
    Thanks !
  3. #123
    boXXer
    Guest
    will you play with my helmet if i tell you?
  4. #124
    Ireland
    3,579
    173
    I just thought I would add where I buy my gearbox parts from
    http://www.transmission-rebuild-kits...-c-84_115.html
    http://www.bearingkits.co.uk/FORD-GE...20d8adaae84806
    Also burton power sell the other little bits like the synchro blocker bars etc
    https://www.burtonpower.com/product_main.aspx?home.aspx
    They sell all the parts you need, all of them can supply the longer front layshaft needles, which are 26mm long instead of 18.75mm long, the longer needles are actually used as the rear layshaft bearing for the 4 speed RS2000rocket/ type E gearbox, the only difference apart from the lenght is that the 4 speed uses 19 layshaft needles/rollers and the 5 speed type 9 uses 21 shorter needles, when making your order request 21 of the longer layshaft needles.
  5. The Following User Says Thank You to RWD fords rule For This Useful Post:
  6. #125
    Sep 2010
    UK North East
    94
    Is there ay advice or guidance books around as i want to have a go and build my own 5 speed box using either a tranx kit or quaife ? .. Or if anyone can show a step by step guid on here that would be fab ,..
  7. #126
    Ireland
    3,579
    173
    Buy a haynes book, to suit a 2.0 capri or similar, the older books are better as they have more detail.
    Regards
    Jason
  8. #127
    Oct 2010
    pewsey
    31
    9
    hi wat cluch do i need for a 1.6 pinto to a t9 box thanks mogz
  9. #128
    Oct 2010
    pewsey
    31
    9
    hi what cluch do i need to go from a 1.6 pinto to a type 9 box thanks mogz
  10. #129
    Oct 2010
    pewsey
    31
    9
    im so confused with it all
  11. #130
    25,127
    buy a 2.0 pinto clutch
  12. #131
    Dec 2009
    New Zealand
    23
    So do you use the 1.6L sierra clutch plate with the original pressure plate or do you use the sierras pressure plate?
  13. #132
    Apr 2006
    Auckland, NZ
    243
    Hey quick question, if I decide to fit one of these gearboxes to my xflow and reweld the mounts etc, then at a later stage decide to also fit a pinto motor, will the gbox mounts line up?
    http://img211.imageshack.us/img211/7983/pete4as.jpg
  14. #133
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    Quote Originally Posted by retep130 View Post
    yep
  15. #134
    Jul 2010
    South Wales
    4,689
    221
    Right i am buying a 2.8i type 9 that has been mated too a 2.0pinto and i want to mate it to my 1600 x flow. At the moment i am not sure what bell housings is attached to it but i would like to know can i use my original starter motor. Thanks, john
  16. #135
    Nov 2003
    Wirral UK
    6,740
    257
    Yes you can
    http://escort.accelerator.org
  17. The Following User Says Thank You to exboyracer For This Useful Post:
  18. #136
    Jul 2010
    South Wales
    4,689
    221
    Thanks for that although thats a shame as mine has just died. It used to turn over slow the first time i started it everyday then it would turn over faster and faster. Then after 4-5 times of cranking it over it would run. The starter would also stick too and make a nasty noise when the engine did start. Any idea what this would be and could i strip it down to fix it.
  19. #137
    Nov 2003
    Wirral UK
    6,740
    257
    Could be worn brushes, or just old and full of crap. Strip it down and find out, shouldn't be a big job.
  20. #138
    Nov 2012
    Milton Keynes
    Wink Re: Type 9 gearbox tutorial
    Hi Anyone here have a T9 for sale at a reasonable price ?
    Also can anyone answer this question, Does anyone here know the measurements
    from end of bell housing to output shaft between the V6 and 2ltr box T9 please ( as im not sure what is fitted to my beast)
  21. #139
    Bristol
    175
    17
    I'm pretty sure that the 2ltr GBox input shaft is flush with the face of the bell housing , where as the V6 shaft sticks out a little bit (aprox 10-15 mm )
  22. #140
    Nov 2003
    Wirral UK
    6,740
    257
    That's the easiest way to tell, the nose of the V6 input shaft sticks out about an inch.
  23. #141
    Dec 2012
    Oslo, Norway
    10
    I've got a T9 and a 4-speed from a 1600 x-flow. Can the endhousing from the 4-speed be used on the T9 so that I don't have to Movie the hole in the tunnel?
  24. #142
    3,246
    Quote Originally Posted by RX1300 View Post
    It won't make any difference - the gearbox is physically longer / stick in rearward position compared to the 4 speed, bell housing depths are essentially the same across the variants.
  25. #143
    Sep 2006
    chesterfield derbyshire
    2,162
    you can have the t9 tailhousing modified to bring the gearlever back into the standard position, it means splitting the rear housing from the box and having it ali welded and then shortening the shift rod.
    i wish i had done this instead of cutting the strengthening arch in the tunnel. regrets, regrets regrets
  26. #144
    Dec 2012
    Oslo, Norway
    10
    But that means a lot of welding and messuring, right? Has to be a bigger job than moving the lever hole in the tunnel? Has anyone got templates for this sort of job?
  27. #145
    Sep 2006
    2,162
    not really a lot of measuring, all you need is the distance from the bellhousing face to the centre of the gearbox lever hole of the original box and then shorten the type 9 housing to give the same measurement. when you move the hole in the tunnel you also have to chop into the strengthening arch in the tunnel. i wish id left mine alone and had the gearbox modded instead.
  28. #146
    Tyre Kicker hessu75's Avatar
    Jan 2013
    Finland
    Hello and greets from Finland,
    Had to register to be able to ask few questions concerning the assembly of the rear housing and fifth gear locking mechanism.
    I have the post-1987 version tranny and the locking plate does not have the pin and spring parts under that plate.
    Now,
    The tranny does not have fifth gear at all atm.
    I have assembled the rear casing wrongly, because before removing the rear casing for welding few cracks, the fifth gear worked.
    Could someone please tell me step by step how do I align parts inside the casing, so that the locking plate will be used correctly and the fifth gear will be engaged, when I select it from the gear stick.
    I have the 32mb pdf file of the gearbox, but it does not tell me this procedure.
    Advice would be very much appreciated!
    Great thread BTW!
    -Hessu-
  29. #147
    Feb 2005
    Norway
    438
    Mail sent
  30. The Following User Says Thank You to Svein For This Useful Post:
  31. #148
    Jan 2013
    Finland
    Hello all again,
    The documentation is all good, but still these documents do not tell me the specific way to install and align the fifth gear interlocking sleeve and the locking plate.
    Help is still appreciated.
    Btw,
    Does the axle, which goes to the clutch and flywheel just pull off, when I have removed the sleeve and bellhousing?
    I have a second gearbox, which is fully operational atm. Just need to change the oil seals. But, it is for four cylinder inline engine. I could just swap the axle from the V6 version, which is missing the fifth gear and problem solved.
    NExt question.
    Can someone tell me the OD and ID measurements of these oil seals? I have no access to the gearbox atm, but can visit a special shop, which sells all kinds of oil seals to automotive industry.
    -Hessu-
  32. #149
    Jan 2013
    Finland
    Yes!
    Fifth gear is fully working again!
    The axle which moves the forks and fifth gear locking sleeve had a broken tap which is inside the locking sleeve. The sleeve moved freely and the missing tap caused the fifth gear not engaging at all.
    Thank you all, who helped me out.
    -Hessu-
  33. #150
    Mechanic gringo!!'s Avatar
    Nov 2009
    Rotherham - in the shed
    978
    147
    What starter motor is used for this conversion? Thanks lads..
  34. #151
    Jul 2010
    South Wales
    4,689
    221
    I am just wondering if anyone knows where to get the 26mm long needle rollers with out having to pay through the nose for them as the only place i can find the is on burtons website they are only £1.70 but times that by 21 ans it starts to get expensive.
  35. #152
    Ireland
    3,579
    173
    They are 4 speed aka rocket gearbox needle rollers, definitely worth buying as the std type 9 ones are much too short and will wear the lay shaft, not sure where to get them cheaper but search for 4 speed needles and you may find them for a good price
  36. #153
    Jul 2010
    South Wales
    4,689
    221
    All sorted now luke sent me this link had a full rebuild kit and other things for £200 the lot. Can'r wait to put it all together now.
    http://www.bearingkits.co.uk/basket....rid=1#shipping
  37. #154
    Ireland
    3,579
    173
    Bearing kits .co.uk sell the Type E needle rollers you are after:
    Here they are, £15 for a set of 19, ask for a price for 21 of them
    http://www.ebay.co.uk/itm/FORD-ESCOR...item5af4a3f234
    http://www.bearingkits.co.uk/RS2000-...NEEDLES/32.htm
    Edit, good man, best of luck with the rebuild
  38. #155
    Jul 2010
    South Wales
    4,689
    221
    Thanks for the help! I have bought the type 9 version on the site the 21 rollers. Found 22 in the box mind ;P if you look on my more door thread you will see i am building a 2,341cc forged engine and a tran x 5 speed box. Should be some fun when done!
  39. #156
    3,246
    Can't work this one out - The Type 9 needles (long or short - your choice) is £5 less!
    http://www.bearingkits.co.uk/TYPE-9-...EEDLES/139.htm
  40. #157
    Ireland
    3,579
    173
    No reason why they would cost more for 4 speed, exact same needles
    Good find, yes now I remember they are the same price for short or long needle rollers if you order them from that website
  41. #158
    Dec 2009
    Tartu, Estonia
    36
    22
    What kind of oil do you guys suggest for the gearbox?
    I found the original oil, 23 quid for a liter feels a bit....expensive.
    in "Taking the fifth" article the suggest Comma SX75W90, the GL4 one i assume.
    Thats what i'm currently going for if anyone doesn't convince me otherwise.
    Also, on the topic of longer layshaft needles, i emailed transmission-rebuild-kits.co.uk and supposedly they have them and the price is even better. 6,75 pounds for 25 pcs. Odd number, but at that price i will not complain.
    Will see if they are the right ones when i eventually get them here, to the other far edge of Europe.
    2x 82' Capri
  42. #159
    Ireland
    3,579
    173
    Castrol B373 LSD Oil, best oil as it can take very high loading but it is thin enough to work with LSD's, which also makes it suitable for gearboxes, as a bonus it is also cheap, works great
    http://www.ebay.co.uk/itm/Castrol-B3...item25826b6db3
  43. #160
    Jul 2010
    South Wales
    4,689
    221
    I'm glad you told me that as i used this oil to cover all my parts in to build it. I will get some moreto fill the box up witn when it is in.
Similar Threads
  1. type 5 gearbox
    By luz008 in forum General Car Banter
    Last Post: 20-03-2006, 12:31
  2. Type 2 gearbox
    By mk2phil in forum Running Gear
    Last Post: 22-09-2005, 14:54
  3. Type 9 gearbox
    By ludsonline in forum The Technical Section
    Last Post: 04-02-2005, 07:34
