Results 1 to 12 of 12
Thread: Valve lift
    Nov 2013
    france
    75
    103
    Valve lift
    Efi head
    just checking valve lift on the exhaust with no springs just spring cup and colletts ant the underside of the spring cup hits the top of the iol seal at 10 mm ? How do you manage to fit a fr30 cam and get full lift ? Leave the stem seals out ? Cheers
    May 2007
    762
    Re: Valve lift
    You machine the seat (base in head) of cast iron to have the correct installed valve spring height
    3,242
    Re: Valve lift
    I think the OP is querying that there appears to be only / less than 10mm of potential valve lift before the spring retainer / collets hits the valve guide - nothing to do with installed spring heights
    25,124
    Re: Valve lift
    are you using particularly tall valve stem seals or something? or very short valves? or has teh head been fitted with removable guides which are not fitted deep enough? as i cant recall having an issue until over 500 thou lift
    9,211
    Re: Valve lift
    1600 valves ?
    Nov 2013
    france
    75
    103
    Re: Valve lift
    Katana , yes you are correct
    Its a standard efi head just removed from the block
    Std crank journals , std bores ,
    So probably never worked on
    As i said
    I took the valve springsout and just curious to see the max valve lift before the head has bigger valve and new K guides fitted
    How can Kent cams say a Fr30 needs no mods ?
    It will not work
    If the seats had been recut at some time there would be more lift ?
  7. The Following User Says Thank You to escortservices.fr For This Useful Post:
  8. #7
    Nov 2013
    france
    75
    103
    Re: Valve lift
    Alladin
    Standard 42 mm valves 111mm long
  9. #8
    Nov 2013
    france
    75
    103
    Re: Valve lift
    Sussed it !
    The pressed steel top hat type seals probably Fords own only allow approx 10mm valve lift
    The Victor reinz type allow over 13mm before the collet retainer touches the valve seal
    Something else learnt through readind the excellent threads
    IE check,check and check again !
    Attached Thumbnails Attached Thumbnails image.jpeg‎
  10. #9
    25,124
    Re: Valve lift
    good job, the pressed steel type are actually cvh not pinto, oe pinto ones were the middle one in the pic
  11. #10
    Nov 2013
    france
    75
    103
    Re: Valve lift
    Graham
    I said i didnt think the engine had been taken apart !
    Just goes to show that without the Grahams and RWD,s etc etc we,ed be bolloxed
    Why put cvh seals in a pinto ?
    Cheers guys
    Stay loose !
  12. #11
    25,124
    Re: Valve lift
    some have a school of thought that they seal better, which is a load of rubbish,
  13. #12
    Nov 2013
    france
    75
    103
    Re: Valve lift
    Cheers G !������
