cam choice for dragracing pinto
Engine spec 11:3:,1 compression ,twin 45mm webers 38mm chokes ,pacemaker large bore exhaust 2 1/4 inch exhaust system looking for best cam with peak hp between 3000 to 7500rpm cheers mario.
Re: cam choice for dragracing pinto
Is comp not a little low for a bf63 ?
Our 80's road rally car only had 10.6.1 Alan on a BF63, with Smitty pistons. The old girl did n't go too bad from what I can remember.
You may. Be correct Gary it went very well and sounded great at speccy points
I'll have mine on a dyno after xmas.
Make sure you post the Dyno sheet. Are you out on the DS this weekend?
