Results 1 to 7 of 7
Thread: Zetec inlet plenum options!
    Sep 2016
    Herefordshire
    I trying to use the original inlet on my Cortina ST170 build but im having major issues trying to get it to fit!
    The inlet plenum is very large and i cant get it clear or the brake master cylinder and that is without a servo fitted!
    I am thinking of getting a custom one made but wanted to know other options first?
    Cost wise, if i can keep using my brake master cylinder a remote dual servo is the best part of £300 to £350.
    Also i have looked at the gen 2 focus ST and i could blank off the one inlet but i dont know the dimensions and still not sure it will fit!.
    25,124
    Re: Zetec inlet plenum options!
    i have heard the st170 plenum can be fitted upside down, dunno if that would help
    Sep 2016
    Herefordshire
    that gives me the space at the back of the engine but its still to big to fit with or with the servo.
    Sep 2016
    Herefordshire
    That's the space I have off the manifold with the servo on!
    Sent from my E5823 using Tapatalk
    Spanner Monkey ugg10's Avatar
    May 2014
    South Coast
    175
    30
    Pepper performance and kit spares doe plenum for,th stock zetec, not sure if they will fit on an st170 though, worth a call.
    http://www.pepperperformance.com/plenum-chambers/
    http://www.kitspares.co.uk/index.php...&search=plenum
    otherwise there are people,that have used wither the rover t series turbo plenum or the Nissan plusar gtir throttle bodies and plenum.
    Dec 2011
    Cowdenbeath
    400
    32
    Can you not loose the servo and fit a bias pedal box
    Sep 2016
    Herefordshire
    Custom is the answer, its not going to be cheap but worth it in the long run.
