Results 1 to 6 of 6
Thread: Alignment recommendations - fast road Escort
    Jun 2006
    Durham, UK
    1,494
    Car is getting to the point of needing to drive on proper roads now, not just up and down the street and in and out of the garage!
    Front spec is:
    - Adjustable gaz coilovers and inserts
    - 250lb springs
    - In-situ adjustable tca's
    - twin-cam style arb and double width brackets
    - eccentric adjustable top mounts
    - +10mm wide alloy hubs
    - 215/45x15 tyres
    Rear is:
    - decambered, single leaf springs
    - gaz adjustable shocks
    - 2" lowering blocks
    - anti-tramp bars
    - panhard rod
    - 225/50x15 tyres
    Last time we did any alignment I didn't have any adjustment in the suspension - so the only thing we had to set was the tracking to standard figures. I've no idea what to set camber to, or if/how caster can be affected to any meaningful degree by the eccentric top mounts.
    Car is definitely not a track toy any longer, it's something that needs to work on normal roads; it's not going to do mega miles though, so it can probably be set to something a little more aggressive than a daily driver.
    Anyone got a set of figures to aim for as a good starting point?
    25,124
    Re: Alignment recommendations - fast road Escort
    id put as much caster in as i could get, with 1-1.5 degress neg camber and toe it in 2mm. as you have power steering lots of caster will give all the benefits of a lot of neg camber without the drawbacks
    3,641
    As above but not that much toe in, id set track at 0 or very slightly toe'd out for a nicer turn in, especially on 15 inch wheels, they dull the turn in a bit. I ended up going back to 13's after my (costly) 15inch wheels experience.
  5. The Following 2 Users Say Thank You to Erikmex For This Useful Post:
  6. #4
    Jun 2006
    Durham, UK
    1,494
    Thank you both. A good point to start from, thanks!
  7. #5
    Bodger Gyver's Avatar
    Dec 2008
    Stockholm, Sweden
    35
    141
    May i ask, why was it costly?
    Sorry if this is slightly off topic.
    Skickat från min FRD-L09 via Tapatalk
  8. #6
    3,641
    Quote Originally Posted by Gyver View Post
    Because i spent alot of money buying new grp4 15inch wheels, trying different competition tyres only to work out that escorts dont handle well on 15 inch wheels, its very difficult to get the geometry correct for them, so then i went back to 13's . All in all - a £2000 mistake.
  9. The Following User Says Thank You to Erikmex For This Useful Post:
