Results 1 to 3 of 3
Thread: Rough idle after ballast removal xflow
    Dec 2015
    Ireland
    33
    14
    So I cut the ballast resistor from my xflow loom
    the car was running 9v and has a 9v coil
    When I switched the car back on it was back firing very hard to rev and rough idle?
    did I do something wrong in the loom
    or is it just the fact the coil is fecked now along with the points
    i thought it would run fine for a while but was rough after the removal of ballast wire ,
    i just want want to make sure before I remove the old 1300xflow for my new 1600 xflow with electronic ignition
    thanks
    25,117
    Re: Rough idle after ballast removal xflow
    the extra voltage by cutting out the ballast will give the ignition system a much harder time, particularly the points but i would expect it to cause what you describe
    Dec 2015
    Ireland
    33
    14
    Thank you for your reply
