Results 1 to 9 of 9
Thread: Pinto rebuild
    Nov 2013
    france
    75
    103
    Pinto rebuild
    Which make engine assembly lube/ grease is best for a pinto rebuild
    25,118
    Re: Pinto rebuild
    something oily! if an engine will stand for a long while before its going to be started/used i use graphogen
    9,208
    Pinto rebuild
    Graham - when I was rebuilding old engines quite a lot ( circa 1983 &#128516 I used to use the STP oil treatment stuff as it was like treacle. No idea if still available but always wondered if it's good/ bad for the job. Any thoughts?
    25,118
    Re: Pinto rebuild
    i think most important is actually to prime the thing properly, unless an engine is going to be dry sumped, when its complete but before the sump goes on, i hold a jug of oil upto the pickup and spin the oil pump drive with a drill, it fills the filter, galleries and you can physically see the spray bar spraying, i do this with an oil pressure gauge connected, with a std oil pump on cold 20/50 you will see 60psi on a battery drill, 70 or more if its an uprated pump
  5. The Following 2 Users Say Thank You to Graham For This Useful Post:
  6. #5
    Mechanic hawk1903's Avatar
    Jun 2009
    istanbul
    956
    269
    Re: Pinto rebuild
    Hi Graham,
    It seems a very good method of priming all the oil system within the engine but would not it kind of wipe off the Graphogen ( or similar engine assembly lubes ) from the mains at least ? Just thinking.
  7. #6
    25,118
    Re: Pinto rebuild
    the whole point of assembly lube is to protect the moving parts until pressurized oil is available when the engine is started, so i dont see an issue even if any were washed away because priming will give instant oil pressure once its started
  8. #7
    Jun 2009
    istanbul
    956
    269
    Re: Pinto rebuild
    I agree. Thank you.
    Anyway, remaining lube will be the additional protection during the start up.
  9. #8
    Nov 2013
    france
    75
    103
    Re: Pinto rebuild
    do you oil the bores if its standing for a while
    ie down the plug oles
  10. #9
    25,118
    Re: Pinto rebuild
    no need if you oiled it when you built it, the most important thing if it is going to sit around for any amount of time anywhere other than a warm dry room is to regularly turn the crank over a turn or so
