Results 1 to 8 of 8
Thread: welding on and off days
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    I seem to have on and off welding days, luckily today was a good day but yesterday was shocking, my machines settings havent been adjusted and im welding the same stuff as yesterday.
    i cant work it out, does anybody else have days like that?
    Jan 2012
    Aberdeenshire
    417
    Re: welding on and off days
    Welding is a skill that takes years to master and even good welders have bad days. Best advice is make sure you are in a comfortable position and if it doesn’t go to plan, chuck the whip or sort it with the grinder
    Practice is the key
    25,124
    yeah been there done that, these days i adjust my technique as much as the machine, cheaper machines tend to be more temperamental, voltage in the national grid can vary a bit from day to day, that probably makes a bit of a difference too, as no doubt does temperature and humidity
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    I know what you mean. On a bad day I just walk away. I get this when I'm using TIG and MIG.
    Mar 2014
    London
    110
    Temperature makes a massive difference when welding and so does your attitude towards it... put the gun down and walk away as we just get more frustrated...we all have a off day
    Jul 2012
    cambridgeshire
    1,054
    Good to know its not just me, i think the advice to just walk away sometimes is spot on
    9,212
    168
    worth checking all connections tight too - plug / fuse and if your competent then check the contactor inside too.
    Jun 2006
    kilkenny, ireland
    519
    Drafts and wind can be a problem, they can blow your shield gas away from the welding pool, resulting in a bad weld.
    I usually save critical welds for first thing in the morning too, when I'm a bit fresher.
