Results 1 to 11 of 11
Thread: Locking exhaust manifold bolts on x-flow in Escort mk1
    Feb 2018
    Blaricum
    What is the best way to lock exhaust manifold bolts on a x-flow?
    Can't use studs, as it would be impossible to take the tubular exhaust manifold off with the engine in situ. There is just a few mm space between the manifold and the brake servo bracket (LHD car). Drill the bolt heads and use locking wire or is there a better option?
    25,124
    Re: Locking exhaust manifold bolts on x-flow in Escort mk1
    lock wire wont keep bolts tight, it will just stop them unscrewing if they come loose
    Bodger Gyver's Avatar
    Dec 2008
    Stockholm, Sweden
    35
    141
    How about Nordlock washers? Should be able to cope with the heatcycling i suppose...
    /David
    Skickat från min FRD-L09 via Tapatalk
    3,242
    Spring washers should work ok!
    Nov 2008
    london
    821
    88
    Loctite
    4,893
    Just make sure the threads in the head are good, use new bolts and tighten them.
    After mounting mark the bolts with respect to the manifold and check regularly that these are still in the same position.
    Wouldn't use Loctite or anything.
    Mar 2012
    2,118
    x2
    Feb 2018
    Blaricum
    Cheers guys,
    I will use new bolts with spring washers and retorque the bolts after a few heat cycles. If the bolts work loose, I will use some NL8 Nordlocks.
    Feb 2012
    United Kingdom
    64
    483
    Do them up tight JD
    run mine for 3000 miles now....all good.
    Tubular s/s manifold using stainless cap head bolts tight 'n tidy.
    Spanner Monkey Fatgadget's Avatar
    Jan 2006
    Camden Town
    266
    Quote Originally Posted by rick deregus View Post
    Loctite
    What sort of Loctite capable of withstanding exhaust manifold temperatures? Anyway what wrong with the old school way of fastening manifolds? Never was an issue was there?
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Can't the studs be screwed in with the manifold in situ?
