i want to id these mounts - i think they are sierra pinto (bolt pattern is pinto) but all the pics i see have a tab on the mount end and these have a slot - are cosworth ones any different to pinto ? cast iron/steel
thats odd as i have never broken a 2.8 sierra can they be non sierra ?
i thought all sierra pinto were alloy, dont think they would be v6. maybe sierra p100, or mk3 transit
looking at pics on web you appear to be correct ( v6 sierra) but its baffling me where i acquired these
If they are 4 bolt...then they are pinto....i have the part nos for the 3 different mk1 sierra mounts r/h only....(the mk1 had the different mount which has the slot)
Cosworth 1986 part no 1641136
ohc 1984 - 1986 part no 6125816
ohc 1982-1984 part no 6136762....
Cheers mark....or give me your part no and ill search...
both mine are 4 bolt
These are the only cars that use the located rubber engine mount(the two bolt jobby)
from 01.02.1985, to 31.12.1986, Cologne V6 2.8 MFI sierra
from 01.08.1982, to 31.10.1984, Peugeot Diesel 2.3
from 01.08.1982, to 31.12.1986, OHC sierra
from 01.08.1982, to 31.08.1984, Cologne V6 sierra
And only the ohc uses 4 bolt fixing...so yes early pinto sierra...
Cheers mark
