Results 1 to 14 of 14
Thread: Oil take of plate
    Nov 2011
    ochiltree
    134
    Oil take of plate
    Hi, could i use a oil filter relocation plate for the return on my dry sump by blanking off one of the holes? The filter take of plates are a third of the price of the single hole plates.
    Cheers😁
    Oct 2013
    Suffolk
    47
    194
    Re: Oil take of plate
    What engine is it mate
    Nov 2011
    ochiltree
    134
    Duratec 2.0
    i have on pintos so i dont see why a duratec would be any different
    Oct 2013
    Suffolk
    47
    194
    Did you not get a Oil in plate with you kit ?
    I make my own for my dry sump kits
    But if you really wanted to you could always use
    A piece of 1/2 alloy plate cut out the profile and put a tapped
    -10 hole in it
    May not look as nice but will work
    Nov 2011
    ochiltree
    134
    i didnt buy a kit, ive been building the car from ebay, bit by bit
    im up for making my own but was not sure if it had to have special flow charactersics also i dont know how i would make the rececess for the oil ring or could i just use a home made gasket?
    Nov 2011
    ochiltree
    134
    I started making one today, will upload some pics when done��
    Nov 2011
    ochiltree
    134
    [atClick image for larger version Name:	20180302_172453-480x640.jpg Views:	80 Size:	75.2 KB ID:	82336tach=config]82336[/attach]
    Nov 2011
    ochiltree
    134
    Click image for larger version Name:	20180312_211742-498x448.jpg Views:	80 Size:	103.8 KB ID:	82337
    Nov 2011
    ochiltree
    134
    Click image for larger version Name:	20180310_192429-498x373.jpg Views:	80 Size:	76.6 KB ID:	82338
    Nov 2011
    ochiltree
    134
    Some pics of this week's work, sorry for the quality, seems t have make pics small to allow upload
    Nov 2011
    ochiltree
    134
    Finished plate in place Click image for larger version Name:	20180321_201028-524x393.jpg Views:	60 Size:	75.6 KB ID:	82429
    Sep 2010
    kent
    227
    very nice work orangepeel! What milling machine do you use? I'm setting up my machine shop and looking at mills but cant go too big as space is precious. Also that cam cover, is it a painted aluminium one?
    Nov 2011
    ochiltree
    134
    Thanks! I like to make as many bits as possible, not just cause im tight��
    I cant remember what its called, its from 1965ish. It does most things but would like a digital control. I painted the alloy cover with 3 or 4 coats of crakle paint and cooked it on top of the garage stove.
