Results 1 to 10 of 10
Thread: Confused by new torque wrench
    May 2009
    Havant
    553
    12
    I just bought a new 22.1 to 154.9 ft lbs torque wrench....but im confused by the extra points on the numbers as ive only ever saw that on newton meters wrenches
    For example i want to torque to 35ft lb but the nearest number is 29.5......does this mean i set the zero at 29.5 then turn the dial 5 and a half times to get 35ft lbs??
    25,118
    Re: Confused by new torque wrench
    Quote Originally Posted by psmk2 View Post
    doesnt sound right but without a picture of it , your not going t get an answer
    4,892
    Have you read the manual?
    May 2009
    Havant
    553
    12
    I can't upload photos for some reason...manual doesn't make sense to me but its a draper model no 3001a
    May 2009
    Havant
    553
    12
    It has the newton meters on the other side and i can work that out easily enough...just means i need to use a conversion tool but i found one in the play store...heres what the manual says
    Measuring Ft/lbs
    Torque wrench set to70.84 ft-lb
    1. Unlock handle
    2. 66.4 ft-lb. Whole number
    3. 1 div. On handle= 0.74 ft-lb
    6 div.=4.44 ft-lb
    66.4 + 4.44= 70.84 ft-lb
    4. Lock handle.
    4,892
    I use 4/3 as a conversion factor (not exactly right but close enough).
    If you need for example 30 lbft torque then that is 4/3 * 30 = 40 Nm.
    Measuring Ft/lbs
    1. Unlock handle
    6 div.=4.44 ft-lb
    4. Lock handle.
    I think you are getting ft lb and lb ft mixed up, they are different measurements. Sorry I can't help on anything else with your torque wrench.
    4,892
    Sorry I did n't read the thread thoroughly in the first post, I was getting confused with inch pounds which are use for very light settings. I had such a torque wrench 35 yrs ago for adjusting the preload on Cummins injectors,
    9,208
    From the instructions it's just a case of making up the number from the nearest number lower on display and then working out how many increments.
    Usually for 84 this would be 80 and 4 tenths on a metric scale but the scale is odd ( imperial ? I can't see the post while replying on phone )
    Edit each division is near 3/4 lb ft rather than 1 😄
