I wonted something that nobody else ad done before. not that ive seen.theres plenty of room for a supercharger and other bits n bobs two make it go faster (sideways)
wot do u think?
wot do u think?
interesting an 318is engine, out of an e36 from the look of the inlet manifold, does the std 4 branch bmw exhaust manifold still fit? and what did you do with the sum?, it would of had a front well from memory
yeah its a e36,the bmw 4 branch exhaust manifold is standerd and the sump as the bowl to the rear,ad to move engine bck 2inch for the sump to clear the crossmember and so that the standard escort colum would fit
Looks great,any chance of making the pics a bit smaller?
Nice looking project
not sure if worked but if not i'l try again later lol
I like it its always good to see out of the box thinking..
Some more smaller pics from wen 1st got the car and how it is now
Some more smaller pics from wen i got car up to today
you have dun a good job on the escort from when i last had it (was running a cossy lump ), bring it around when its on the road i would like a go in that with the bmw engine in it ,
alrite m8 will do
more technical details of the transplant please
engine & box is out of a k reg car without the chip key u only need 3 wires to get this engine running with the injection on it,its got a bmw loom with the ecu & exhaust manifold with down pipe witch you have to exstend 2",prop needs fettle to fit,the clocks are mk2 but with the oil,batt n rev counter wires joined to them from the engine loom.engine mounts were made by my m8 james who also did the tunnel & gearbox mount(TOP CHAP)the tunnel has to be cut out rite back coz the bm prop sits high up but the engine its self is about 2" back so that the sump fits just rite & u have to move the handbrake to one side.u put a shorter fanbelt on coz u take the powerstering pump off (QBR61513) the bm radiator fits with the hoses ok other bits you just sort as you go along.
cheers
just bin up the street in my scort for the 1st time couple of bits to sort then of for the MOT
well done matey
first time i've seen this project!!
get that vid on tinternet sqeaky
the 318 is was never a quick car imo, but that lump in a mk 2 should be a pretty nippy car good to see people using alternative engines on here and you cant beat the bmw's reliability but i personally would have gone for the straight 6 from an e30 325 with a slipper = tons of fun!!
Hi mate, not doing this to diss you or owt, but you aint the first.................good job on keeping the BMW theme though.
This was my old Sunbeam, 945kgs, 400bhp..........
I also knew a fell that had fitted an S14 (E30 M3 engine) into a Mark 2, he also had installed it in the upright position which had caused some major issues.
Looks real good though mate, also, engines are peanuts now!
i do like the 6 pot engine but this engine was cheap n sat doin nowte so in it went lol a slipper is on the shoppin list wi some new struts & brakes
that bumsean looks the dogs b's i bet it was a hand full in the wet lol did the sump clear the crossmember ok?my mates just offerd me a 6 pot to put in my 100e
scort has passed its MOT todaytime to get some miles on the clock
bring it around m8 , i want to play in it hehe
just fitted some billies front and rear should drive a lot betta now coz it was a bit on the bends with the other stuff on
Hi scort2.
Very nice project.
I also want to do same project.
Can you help me with your know-how!?
Thanks and kind regards
