Results 1 to 5 of 5
Thread: Cologne v6 tripple webers help wanted
    Spanner Monkey mihakrapez's Avatar
    Jan 2007
    Ljubljana, Slovenia, Slovenia
    271
    18
    Hello boys and girls.
    I made a Triple weber 40 DCNF setup on my 2.8 cologne and have some questions:
    -What kind of ignition timing should I go for?
    -What kind of pressure should I pump into the carbs
    -I have no return line for gasoline. Should I make it or is a filter king with bowl enough?
    -Burton says that these carbs are not jetted any ideas on what kind of jets should I use?
    I am a noob with carbs so your help would be much appreciated.
    Click image for larger version Name:	30443013_10213584133250732_4231689444043784192_o.jpg Views:	79 Size:	105.1 KB ID:	82590
    Obstacles are those frightful things you see when you take your eyes off your goal.
    25,124
    Re: Cologne v6 tripple webers help wanted
    the carbs will have jets in them, they are just saying they may not be right, you need to get it dyno'd. the chances of anyone on here giving you a jet setting is slim to none
    Jan 2007
    271
    18
    What about pressure
    25,124
    around 2.5 psi
  5. The Following User Says Thank You to Graham For This Useful Post:
  6. #5
    Tyre Kicker 3.5cologne's Avatar
    Jun 2017
    New Zealand
    Looking at your photo, I was lead to believe that the DCNF carbs for the V6's were meant to have the fuel bowls at the front, to stop fuel lean out under acceleration. All the installations of triple carbs for the Essex and Cologne I've seen have been with the fuel bowls forward. Nice setup though.
