Tapping a Duratec water outlet for an M10 sender
Hi All
I want to tap the unused boss on the back of the Duratec head water outlet for an M10 sender adaptor, The pre-existing partial drilling is 9.2mm, is this too skinny to tap an M10 thread in and still get a good seal? The M10 bit is for a threaded adaptor to put a 1/8NPT vdo sender in, so I could go up to M12 I think as there is enough meat in the casting and get a new adaptor.
Re: Tapping a Duratec water outlet for an M10 sender
it is too big to tap an m10 thread in, but you could helicoil or insert it to get an m10 thread
Kind of what I thought. I have the drills / taps for m12, and the housing will take it, so I think I will get an M12 adaptor and see how it goes.
