Results 1 to 9 of 9
Thread: Removing oil from gearbox
    4,892
    Hello,
    I want to change the oil of a Type E gearbox whilst it being on the car (Mk2 Escort).
    What do you use for this job?
    Tried a Draper oil suction thingy but it sucks ...
    Maybe an oil fuelpump?
    Regards, Leon.
    25,119
    Re: Removing oil from gearbox
    take the prop off and jack up the front of the car extremely high????
    9,208
    I put a drain plug in my type nine while in situ. Not sure if a type E has a similar spot on bottom of case to tap ?
    4,892
    I meant old fuelpump not oil fuelpump ...
    Jacking up the front could be a solution.
    Drain plug is maybe a solution for the future, want to make sure that no debris from tapping the hole ends up in the gearbox.
    Oct 2008
    whitley bay
    2,436
    89
    Any pictures of where to drill and tap on box?
    Hexham and District Motorclub
    May 2004
    Norn Iron
    1,142
    I dont imagine any typical fuel pump handling oil at all.
    Can you get a tube down into the trans ? Some of the large vacuum oil/fluid extractors would be an option if you can.
    Otherwise drilling and tapping a hole in the bottom of the trans should be pretty easy and mostly risk free. Say for a NPT or BSPT type plug.
    Oct 2008
    italy
    471
    21
    I used a vaacum operated oil drainer. Like these we use on olds Smart being the oil pan without any hole to drain engine oil
    4,892
    I borrowed a large vacuum oil extractor from a friend so will give that a go.
    Also he gave me a 1/8" NPT plug if I would go for drilling and tapping a hole.
    9,208
    Use grease on tap to trap swarf
