Results 1 to 10 of 10
Thread: Fuel Pressure for ITBs and standard blacktop fuel rail.
    May 2009
    Cape Town
    35
    Anybody?
    9,210
    Re: Fuel Pressure for ITBs and standard blacktop fuel rail.
    fuel pressure is normaly circa 3 bar approx 43 psi
    if that was the question?
    May 2009
    Bishops Stortford
    88
    That's about right. For a 2.0 duratec it's 3 1/2 bar
    Dec 2007
    Dubai
    1,678
    29
    yep ran mine at 3 bar
    www.gulfpetrolheads.com
    May 2009
    Cape Town
    35
    Ok cool...so a 4 bar fuel pump would work?
    9,210
    yes pressure wise but you still need a regulator (after rail in return line) to put pressure at rail down to 3 bar.
    May 2009
    Cape Town
    35
    got a standard regulator on so think that would be fine....
    Brum Town
    1,822
    26
    the blacktop fuel rail pressure regulator pressure is 270kpa (2.7 bar) IIRC.
    Feb 2019
    north yorkshire
    This is a necro but...
    There are two very different zetec "black top" engines. The OG Zeta and the newer Sigma.
    The original blacktop Zeta, or Zetec-S, was made in only 1.8L & 2.0L (inc. ST170 and mk1 RS Duratecs) and uses a 380Kpa fuel pressure regulator (Ford #1053950) which looks like this (vac pip straight out the top, 90 degree angle on fuel pipe at bottom, attachment to rail at the back) >>
    Click image for larger version Name:	s-l500.jpg Views:	55 Size:	19.8 KB ID:	83619
    The newer Zetec-SE (Yamaha collab) is made 1.25L, 1.4L, 1.6L and 1.7L (VVT) and uses (I think) 270 Kpa regulator for roughly pre 2010 which looks like this >>
    Click image for larger version Name:	38628f2a-5183-40ad-bae6-dc5afc1d19d9.jpg Views:	55 Size:	12.0 KB ID:	83620
    Whatever it looks like (the later sigmas uses a different regulator i think) you'll know pretty quickly that you've the wrong one. As you will with the "dromedary" fuel pumps that are sold for £10-£20 that are supposed to work for 1.4 1.6 1.8 and 2.0L. They don't work for black top 1.8 and 2L as they're only 3 bar. The right pump is 4 bar and I haven't found a pattern one, only a bosch for about £40. The 3 bar will fit if you ram the multiplug in, as the groove is on the wrong side (I found a 3 bar with the groove on the right side as well - didn't work) and it will probably make your car move a few hundred feet at a time depending on how much you push it and you will question life itself until you realise it's the wrong thing.
    25,124
    9 years after the last post but thanks for that
