Results 1 to 7 of 7
Thread: new engine spec
    Aug 2017
    Pwllheli
    16
    new engine spec
    hi here is the spec of my engine any advice on your thoughts about it, will be going in a ford anglia 105e road rally car 1360cc
    Bore/Stroke 83/63 (1363.48)
    Crankshaft:
    Manufacturer: STD Ford Balanced
    Max Rpm: 9000
    Stroke: 63mm
    Flywheel Mounting: 6 Bolt
    Block:
    1300 GT – 711M 181 Deck Height
    Bore: 83mm 96.012 spacing
    Camshaft Bearings: STD
    Main Brg Caps: Standard
    Bolts: ARP
    Conrods:
    Type: Ford 1100cc
    Length: 110mm
    Supplier: Specialised Engines
    Bolts: ARP
    Pistons:
    Bore: 83 mm STD + .090”
    Supplier: STD AE
    Compression H: 39.5mm
    Machining Volume: 25.5 cc Piston – 10.5:1
    Machining Geometry: Custom - OJC
    Oil System:
    Dry Sump Pump: Side mounted Pace 5 port 2 stage - Titan
    Dry Sump Pan: Alloy - Titan
    Head:
    Type: Flat
    Supplier: Vulcan Big Valve full gas flowed
    Inlet Valves: 41mm Dia.
    Exhaust Valves: 35mm Dia.
    Cam:
    Type: Kent A6
    Supplier: Kent Cams
    think first thing will need to be changed will the cam
    thanks
    Jun 2014
    leeds
    58
    127
    Re: new engine spec
    junk the pistons, you'll be lucky if they stay together at 9k and fit a steel flywheel double dowelled.standard mains bolts would be ok, spend the money on proper pistons. 234 cam
    Aug 2017
    Pwllheli
    16
    Re: new engine spec
    to be honest think ill have my rev limiter set well before that thanks what cams work without much more pistone work thanks 244?
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Re: new engine spec
    STD crank, not a chance to keep it alive at that rev, even at 8k.
    and I'll run away when I see "Supplier: Specialised Engines", 2 mates had several engine failures with engine from them, they mix conrods type in same engine !
    Your A6 cam doesn't match the whole thing. I had that cam with an all steel engine, rev at 8.5K. This cam is a old design but for me, it worked well.
    25,124
    Re: new engine spec
    i somewhat disagree on the crank, ive known people run std 1300 cranks to 9K, and yes forget the std pistons, they wont like the revs or compression, machined twin cam pistons could be the way to go
    Jun 2014
    leeds
    58
    127
    Re: new engine spec
    1300 crank no good for 8k, its ticking over at that. get some 1100 rods, a short flat top piston machined or not to suit the CR you require and you can fit any cam you want. the old cosworth cams still work well,i ran an A8 with high lift rockers in my 1860 but for road rallies unless you have very low gearing you need a milder choice obviously hence the 234 suggestion which i have used previously in 1300's with good results. high compression, high revs and lots of advance (with ignition to suit) will make a surprisingly quick engine if done right
    May 2007
    762
    Re: new engine spec
    Std crank but balanced will be OK I guess, forged pistons are the way to go (lighter and stronger)
    Flat pistons and head with chambers works also !
