Results 1 to 13 of 13
Thread: changing from dcoe 40's to 45's?
    Aug 2015
    Leeds
    767
    I have some twin 40's on my pinto that are jetted as follows
    idle 45f8
    main 145
    a/c 180
    32mm chokes
    can someone offer any advice on jet and choke sizes based of my 40's
    running a Newmans ph4 276 deg cam, ported injection head, standard valves,
    I have a big valve head for the car but currently using it for auto testing and don't want to pull it apart just yet.
    3,641
    Re: changing from dcoe 40's to 45's?
    36mm chokes, F11 or 16 etubes, 145 - 155 main, 45 - 50f8 idle, 180 Ac, then stick it on a rolling road
    4,899
    Could give a starting point for jetting but my advice is with that cam don't use 45's.
    25,127
    i dont see an issue with 45's, dellorto used to recomend trying 45's on a standard engine!
    Aug 2015
    Leeds
    767
    I may just leave it for now and save the 45’s until I have built my other engine up.
    Would you not recommend the 45’s cause I may loose low down grunt?
    3,641
    All depends on what chokes youre using, ive ran a set of 45's on a std Pinto with 34mm chokes and it was very torquey. Theres certainly a fair bit to gain from going up from your 32mm chokes, a Pinto needs 34's at least.
    4,899
    45's mean going up in choke size, 36mm chokes are too big for a std cam or a Newman 276 cam.
    Using 34 mm chokes in the 45's will mean gaining a few bhp on top end and loosing low range torque.
    When the application is autotest you don't need the extra few bhp on top end.
    Aug 2015
    Leeds
    767
    Thanks for this.
    3,641
    Im not sure why you think using 34mm chokes in a 45 will lose low down torque?? 36mm chokes work well in a std Pinto.
    Jun 2009
    D
    284
    for an uprated pinto you should not use 40ies at all.....a well jetted 32/36 does the job up to 150HP....more than that...go to 45īs...
    3,641
    40’s massively outperform a 32/36, I’ve ran 40’s on really torquey fast road engines, far far smoother than a 32/36 or 38DGas, it’s not just about peak power. Swapping from a twin choke to 40’s on an engine with a fast road cam is like night and day. Granted they only really flow enough for about 150hp but will produce a much nicer low to mid range and idle than a twin choke single
    25,127
    i'd agree on that
    Feb 2011
    ireland
    1,019
    241
    From what I've drove I agree yah.
    What chokes you recommend on 40's here?
