Results 1 to 6 of 6
Thread: What is good coil to pinto with Bosch distributor?
    Tyre Kicker Kollo's Avatar
    Apr 2007
    Finland
    31
    What is good coil to pinto with Bosch ditributor?
    I think its this kind of set:
    http://media.turbosport.co.uk/2006/8...1500661622.gif
    There is just some cheap coil now and its working fine, but maybe it can handle better coil?
    I think primary have to be 0.7 - 0.9 ohms.
    Dry or wet, what are you using??
    Car is Escort mk2, 2xDellortos, bp285 cam, little bit ported injection head with std valves, about 10.5 compression, Denso W22EPU 14mm plugs.
    4,895
    Re: What is good coil to pinto with Bosch distributor?
    I would go for a good coil (for electronic ignition) like this one:
    http://www.burtonpower.com/bosch-ign...221122450.html
    Apr 2007
    Finland
    31
    I have noticed that in Burtons, maybe its good enough.
    Are more powerful coils just good looking but waste of money or can I get couple hp and better spark at starting etc?
    25,124
    you need enough spark, going bigger stronger wont get you anything. if your current set up works ok without missfiring i very highly doubt you will find more power with a coil change
    Apr 2007
    Finland
    31
    Ok, thanks. I was hoping that some nice bling bling coil helps to get couple of hp, but maybe I keep my basic coil
    Mechanic hawk1903's Avatar
    Jun 2009
    istanbul
    956
    269
    Always Bosch coils.
