Results 41 to 80 of 116
Thread: Mk1 build starts
  1. #41
    3,641
    Re: Mk1 build starts
    Also the transmission losses are much more with an rx8 box due to increase gear tooth profile
  2. #42
    9,211
    Mk1 build starts
    Fair enough
    But for clarity they are only very slightly heavier and very slightly larger than a type 9 ( I have both). Cable clutch option available. 5 helical close ratios and a usable 1st gear for town.
    Shame about the big teeth I guess 😄👍
  3. #43
    3,641
    I think what you gain in having 5 decent ratios you lose in weight and transmission losses. I will be making an Rx8 carbon prop to fit type 9 - English tho, for my Mk1 and Mk2
  4. #44
    I have a RX8 prop and for some time considered doing the same. i's on my long list of things i would like to do.
  5. #45
    3,641
    I picked up two on eBay for £40, just need a couple of joints
  6. #46
    Jan 2005
    up north
    670
    for a road car as long as its not dogs or straight cut it will be fine,the mx5 box is another left field option,
    although is a new helical bgh not in the £800 region so not much more than a conversion.
  7. #47
    3,641
    Yeah I have a straight cut dog box in my Mk2 hillclimb car. £1300-2000 for a close ratio with heavy duty synchros and bearings
  8. #48
    2,659
    268
    Is that a quaife dog box in your Mk2 then, 5 speed? And what are the heavy duty synchros, steel or brass?
  9. #49
    3,641
    Tran X 5speed. Yeah steel baulk rings
  10. #50
    Mar 2016
    North Wales
    238
    15
    My build, which is very near completion, is almost identical to yours mechanically. Just for reference, I kept the original tunnel as my shell is a Mexico and really didn’t fancy chopping it too much but if your using a Retroford cast sump with original cross member, you will need to use one smaller engine mount so the gearbox doesn’t hit the top of the tunnel. Then the sump hits the rack, so I had to lower the rack around 10mm for clearance.
    I had my type 9 built by Quaife and thought it nice to have the alloy lid, wrong choice as this made the gearbox too high again.
  11. #51
    3,641
    Thanks for the info, I have a gearbox tunnel riser plate
  12. #52
    3,641
    Took the Mk2 out tonight for some motivation
    Click image for larger version Name:	DB0146D5-006C-43A9-BF3C-1002F4F37200.jpeg Views:	400 Size:	175.5 KB ID:	83148
    Click image for larger version Name:	A5DB17AC-B052-44D8-8752-316CCD78F63C.jpeg Views:	396 Size:	191.3 KB ID:	83149
    Click image for larger version Name:	848B9F78-8F2B-474D-88C4-5242F1F443CB.jpeg Views:	397 Size:	162.2 KB ID:	83150
  13. #53
    Pit Crew Decade Plus User Blower's Avatar
    Mar 2004
    yorkshire
    lovely pair of motors
    looking forward to the build
  14. #54
    2,659
    268
    Nice..
    I wondered what your MK2 looked like.. Forest arches rather than Tarmac, looks nice..
  15. The Following User Says Thank You to rallyrob For This Useful Post:
  16. #55
    3,641
    Yeah I’ve always preferred Forest arches....below the swage line
  17. #56
    2,659
    268
    Me too, no one but me likes them on a Mk1 either...
  18. #57
    3,641
    Oooft, controversial, I thought about arching the Mk1 but really liking the clean Twincam look on steels
  19. #58
    2,659
    268
    Yea I like to be different... Though it's going nowhere fast atm and has been for a very long time... It would make for a very boring world if everything looked the same. I do like the Twin Cam look on steels too..
  20. #59
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    806
    This'll be a belter mate! Well need to take a wee drive in our Escorts once you get it finished up!
  21. #60
    3,641
    Front end starting to go back together, ended up replacing the upper bulkhead, heater bubble and fitting a big tunnel. Also had new strut tops, front crossmember, complete front panel, chassis gussets, wings, rear arches and rear panel, still amazed how good the floors a posts etc are. Will be soda blasted underneath before paint. Click image for larger version Name:	BF544E1F-2D37-4EA6-AE24-689AE2EEA20A.jpeg Views:	347 Size:	182.1 KB ID:	83241Click image for larger version Name:	9C764CF5-0220-45F2-B595-085D844BA497.jpeg Views:	351 Size:	244.5 KB ID:	83242Click image for larger version Name:	DD297E1C-2350-47A9-BC62-E1F3DF897726.jpeg Views:	349 Size:	153.5 KB ID:	83243
  22. #61
    3,641
    Mk1 cracking on, panels all fitted, tunnel done, now in the process of welding in the seat bars then she goes off to have under the wings, floor etc blasted before going for paint prep, still looking for a rear cage if anyone can help?Click image for larger version Name:	IMG_2345.JPG Views:	311 Size:	81.6 KB ID:	83592Click image for larger version Name:	IMG_2346.JPG Views:	310 Size:	78.7 KB ID:	83593Click image for larger version Name:	IMG_2343.JPG Views:	309 Size:	79.1 KB ID:	83594Click image for larger version Name:	IMG_2342.JPG Views:	310 Size:	72.5 KB ID:	83595Click image for larger version Name:	IMG_2347.JPG Views:	308 Size:	84.0 KB ID:	83596Click image for larger version Name:	IMG_2348.JPG Views:	307 Size:	90.0 KB ID:	83597
  23. #62
    3,641
    Im amased at how good the floor is on this car, ended up replacing the drivers side front floor pan as it was slightly pitted, also did the upper bulkhead and heater bubble and replaced the centre rear boot floor with a new panel as the original was a bit pitted and thin when the rear panel was welded on. Front wings are just held on with self tappers at the mo, to be removed to have the inner wings/under arches soda blasted, then will be spot welded on. Dash panel will also be blasted and sprayed satin black.
  24. #63
    Dec 2011
    Cowdenbeath
    400
    32
    Soda blasting doesn't really remove rust I had to blast mine with a fine media
  25. #64
    3,641
    Its worked great so far, its not really rust, just loose paint and fine surface rust, much gentler to the steel than grit, less heat generated too, not looking to remove much material just a nice clean surface prep for epoxy priming, less labour than doing by hand.
  26. #65
    Dec 2011
    Cowdenbeath
    400
    32
    Aye have used both on my mk2 and if you use crushed glass it gives best of both worlds removes rust and leaves panels with a nice surface finish
  27. #66
    3,641
    I didnt really need much abrasion to clean up this shell, it came from Malta, one of the best Mk1 shells ive seen in a while, someone had painted the underside in red lead at somepoint and it really protected it, the red paint you see on the floors is how it came. Its just a bit scaley in some of the hard to access place that would be a pain to prep by hand, blasting makes light work of it.
  28. #67
    3,641
    Floors all now fully blasted, ready for seam sealing and the painting process to start.Click image for larger version Name:	IMG_4017.JPG Views:	235 Size:	65.6 KB ID:	83868Click image for larger version Name:	IMG_4018.JPG Views:	238 Size:	78.3 KB ID:	83869Click image for larger version Name:	IMG_4019.JPG Views:	236 Size:	64.8 KB ID:	83870Click image for larger version Name:	IMG_4023.JPG Views:	237 Size:	60.1 KB ID:	83871Click image for larger version Name:	IMG_4024.JPG Views:	236 Size:	52.2 KB ID:	83872Click image for larger version Name:	IMG_4029.JPG Views:	238 Size:	83.8 KB ID:	83873
  29. The Following User Says Thank You to Erikmex For This Useful Post:
  30. #68
    25,124
    wow thats looking great
  31. #69
    3,641
    Im amazed at how clean it is after blasting, its an early 68 car too, everything in those photos is original with the exception of the boot floor section between the chassis legs which we replaced as there was some minor rust.
  32. #70
    9,211
    Mk1 build starts
    Lucky boy 👍
  33. #71
    Bodger Richb77's Avatar
    Jan 2018
    Outside Berlin, formerly Newmarket Suffolk
    22
    just wondering here how people with big powerful engines in the base model cars tackle the body moving on the chassis issue?
    i recall my first car ('72 1300) the body twist was noticeable when i was turning hard corners.
  34. #72
    25,124
    Quote Originally Posted by Richb77 View Post
    its monocoque there is no chassis! but yes you correct the body will flex, a decent rollage will take car of that though
  35. #73
    Jan 2018
    22
    OK, OK. Yeah its a monocoque. I just call it body and chassis regardless...Which as a designer in Automotive isnt best practice!
    Oh and thanks Graham! Now i have to add a cage to my list....
  36. #74
    25,124
    or as all the US TV shows call them a "uni-body"
  37. #75
    3,641
    Lots of bracing, fab work, gussets, cage, seam welding..................
  38. #76
    3,641
    Google image search some Escort Group4 shells and you'll see some of the fab work that goes into them for competition, this car is just going to be a fast road car so has only had some minor bracing work and axle location, enough for the sort of power and grip levels im aiming for.
  39. #77
    Jan 2018
    22
    Great advice. I want mine to be GT spec plus a little...But being built on a base model i will need to take care of that. Cheers fellas.
  40. #78
    3,641
    Chassis gussets, cage, strut brace and decent axle location is good enough for a road / ocassional track car with modest power.
  41. #79
    Dec 2011
    Cowdenbeath
    400
    32
    Any progress to report on this
  42. #80
    3,641
    Its away for paint so nothing too exciting to report, just a bit of seam sealing and panel prep
