Results 1 to 14 of 14
Thread: Xflow breather system, lot's of oil
    Sep 2010
    Ypres Belgium
    78
    Hello guys.
    My Xflow max power is at 5900rpm.
    When I go to 5900-6200 rpm, I get a lot of oil in the catchtank. Don't know where it comes from, from the breather at the rocker cover or crankcase pressure...
    I have steel crank and rods and I would like to change my speed range a little higher. I now have 34 chokes and thinking about changin them to 36.
    But when I go to a higher speed range I'm afraid I get more oil in the catchtank..
    Anyone can tell me the reason and/or solution of the high quantity of oil?
    Thanks !
    25,120
    Re: Xflow breather system, lot's of oil
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Even with that deflector on blanking plate, I also have a lot of oil in catch tank, but only when bed in new pistons.
    After that period, 500 to 1000 km, think got better.
    then afterward I used one things seen on this forum, one pipe to breathe from block to rocker cover, at the back. Then front rocker cover to catch tank. Things were improved a lot.
    Sep 2010
    Ypres Belgium
    78
    Hi Graham, no I don't. Haven't seen that before. I will buy one of those. Thanks!!
    Sep 2010
    Ypres Belgium
    78
    Quote Originally Posted by Mkdu View Post
    Do you have a pic of it please? With your system you will have a lot of oil in the rockercover... doesn't it do any harm?
    Oct 2009
    417
    14
    Some engine builder recommend this.
    Oil in top of engine will go down anyway. I run the engine a while with no issue.
    Also some used, from the breather a pipe to return oil in sump.
    A lot of posts are talking about this subject.
    This one is interresting
    Head: Rocker cover is tin original xflow. The oil cap is the one used on Pinto's, vented with vapours exit on its side. From the cap, a suitable hose (I think to remember the diameter is similar to heater hoses) goes on the other side of the engine bay to an open catch tank. So lenght could be something like 60/70cm
    Block: kept the original xflow vapour separator box but without the valve. From the box there is another similar hose (the one I'm been able to introduce in place of the ball valve assembly) going as straight vertically I can (30cm?) in engine room and then to the same catch tank. The lenght here is also nearly 1 meter. Probably (I don't remember) I pushed a sort of wire meshed steel like this at around 15cm from the vapour box, inside the hose.
    http://www.ebay.com/itm/NEW-Fiat-500...-/301366423015
    it is not really there as a flame trap but rather as a "stop" for excessive oil, leaving only air and vapours to pass.
    The original fuel pump is not there any longer. There is a blank plate made in alu, without any kind of deflector
    Oil pan is completely std, no baffles
    When I look at the catch tank, there is only water and some bubble of oil, nothing really.
    Just for info.
    I don't know how much a xflow can tollerate excessive ign advance before real knockin can be heard. But if there is too much advance not needed, it can increase crankcase pressure.
    Hope this helps
    http://www.turbosport.co.uk/showthre...ngine+breather
    Sep 2013
    Matlock
    252
    36
    As well as the deflector on the fuel pump blanking plate, most "competition" type camshafts for high rpm use have the fuel pump lobe removed, as it is well known to act as an excellent device to pump oil straight up the breather outlet!
    What camshaft are you using? Does it still have the fuel pump cam lobe?
  8. The Following User Says Thank You to MemphisTwin For This Useful Post:
  9. #8
    Sep 2010
    Ypres Belgium
    78
    @ Mkdu; I now have the same system as you have. Both hoses go to the catch tank, and approx with the same lenghts as yours. But I can easy fill a bottle of 200Ml in 15min when I go High revving.
    Advance is at 6 degrees I thought.
    @MemphisTwin : Cam is a KentCams 244... Don't know if it has the cam lobe, I think so.. It's been A while I have build the engine
  10. #9
    Feb 2012
    United Kingdom
    64
    483
    What make / grade of oil are you using ?
  11. #10
    Sep 2010
    Ypres Belgium
    78
    Quote Originally Posted by piekey View Post
    20w50 VR1 valvoline.. Don't think this will make a difference?
  12. #11
    Apr 2016
    Langley BC
    96
    This is what I ended up doing in my Anglia, old picture, I've since run the block breather up to the middle of the rocker cover between the webers, my compression was also around 120 anyways so I've since done a rebuild. I haven't fired the motor so I can't comment yet on it's effectiveness but when I would drive before, even 20km I probably had about 200-300ml of oil in my catch can. The blowby was terrible.
  13. #12
    3,242
    As a breather hose - that is pretty small bore ..... maybe 3/8"? Rule with breathers 'Bigger is better'. I use two 3/4" bore pipes on my Zetec and have 3x 3/4" on a turbo'd bike!
  14. #13
    Sep 2010
    Ypres Belgium
    78
    @ Llanglia, So you also didn't put an exhaust on the catch can to return the oil to the block?
  15. #14
    Apr 2016
    Langley BC
    96
    No I didn't, It's got a screw off bottom I just manually empty it back in if it was clean. Gonna fire up new motor tomorrow shouldn't hopefully have the blowby and oil issues the old one had.
