Results 1 to 10 of 10
Thread: Lotus twincam oil pressure
    Dec 2017
    20
    Hi ,
    I am starting up my new build lotus twincam engine .
    i started testing the oil pressure without spark plugs .
    i need to turn the engine around for 40 sec before the light goes out .
    if i try again 1 min later its the same again ... nearly 40 sec ....
    the engine has a high pressure oil pump with sandwich plate and oil cooler .
    is this normal it takes so long to build up pressure ?
    4,893
    Re: Lotus twincam oil pressure
    That's not normal. Instead of the oilpressure-sensor-switch fit an oilpressure gauge and see what that gives.
    3,242
    Agreed - even a 'dry' / rebuilt engine, plugs out should put the light out in less than 5 - 10 seconds ...... they are usually only rated at 5psi. Gauge will help but something is wrong!
    Jan 2008
    Up the garage
    2,775
    218
    Quote Originally Posted by Kenno View Post
    Hi ,
    Did you check crank to bearing clearances?
    it wouldnt surprise me too much if the first prime took 40 seconds, but that should be a one off. subsequently cranking and the oil light should be near instantly out. i have had this before on an x/flow with a cracked oil pump body.
    Dec 2017
    20
    Hi ,
    All bearing have veen measured and replaced .
    The oil pump is a new high pressure from burton .
    I wil use a gauge today to see how much the pressure really is .
    How much bar should i have ?
    Kenny
    I just started my lotus tc up yesterday and once warmed and running about 40 psi was showing
    Ignore the the oil temp it’s not connected.
    Dec 2017
    20
    Hi ,
    After trying a bit ... when the engine starts up oil pressur builds up quick
    I have now 65 psi .
    Maybe the starter motor is not running the engine over fast enough .
    Jun 2014
    leeds
    58
    127
    pressure relief valves on the pump have been known to stick open sometimes and then mysteriously fix themselves
    Mine would if left a while lose all pressure and you would have to re prime the pump by removing and filling with oil. It seems ok now and the start yesterday was after 6 months.
