Page 2 of 2 FirstFirst 1 2
Results 41 to 51 of 51
Thread: lotus/ford twin cam
  1. #41
    Tyre Kicker briang's Avatar
    Jun 2018
    chesterfield
    28
    Re: lotus/ford twin cam
    the more i look at the graph the more impressed i am with it, 154bhp from an X/flow usually needs a 254 cam, which gives zero bottom end power, just shows how right the lotus head is
    And that's why, when I built my Caterham 30 years ago , I fitted the twink rather than a x-flow
  2. #42
    25,117
    Quote Originally Posted by briang View Post
    in this instance i think the only win for the x/flow would be cost, twin cams are anything but cheap. also as i discovered its not easy to build and engine which never actually existed from bits form here there and everywhere
  3. #43
    25,117
    if you could find a set for less that 5K, i recon it would be worth trying a pair of 42dcoe on this engine
  4. #44
    Spanner Monkey Turbosport Subscriber chrisis's Avatar
    Apr 2011
    cyprus
    200
    11
    Twin cam is nice engine if you can find one and you don't require over 135hp as this is the head flow limit.
    To properly build a lotus twin cam good for 150hp you need proper gas flow, big valve head with 420 cams.
    The cost of the above is well above 5 steel xflow, especially if you have to pay someone to build/gas flow the head.
  5. #45
    25,117
    its defiantly an expensive engine to build 180bhp pintos are dirt cheap by comparison!
  6. #46
    When we were Rallying Twinks 40 years ago we had one engine that was bored to 85mm with a Xflow bottom end giving 1760cc. It had a big valve head, L1 cams and 45 dcoe carbs with 34mm chokes if my memory's correct.
    For some reason we decided to try a set of 40's off another Lotus engine and I was amazed how much sharper the bottom end power was. We never went to Rolling Roads in them days to compare power figures, jetting was done with a thrash up the road, stop and remove a spark plug to check it's colour and jet as required out of a small selection we had in a tobacco tin. Needless to say we eventually fitted the 45's back believing bigger was better.
  7. #47
    25,117
    a little progress, today i fitted the clutch Ap racing plate and a helix cover, interestingly the plate had valeo a friction lining and the cover was stamped LUK. Id been sent a bellhousing, which i gave a quick clean and chased the rust out of the threads and bolted the starter on, which thankfully cleared the sump and cranks the engine over nicely.
  8. The Following User Says Thank You to Graham For This Useful Post:
  9. #48
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Same for the AP clutch plate for an Pinto. Was not the case 5 years ago.
    By the way the AP cover I used aren't available anymore for pinto.
  10. #49
    Mar 2008
    North Wales
    214
    10
    Thanks Graham for the thread; really interesting stuff. Pics are great too.
    Are we there yet?
  11. #50
    25,117
    since the engine was dyno'd its had a filter back plate fitted and works type linkage fitted.
    it was clear the idle and balance of the carbs would be well off, luckily by now i had everything i needed to run the engine, so i was able to fire it up sitting on its stands
    https://www.facebook.com/graham.bahr...3306848317830/
  12. The Following User Says Thank You to Graham For This Useful Post:
  13. #51
    3,242
    Love the cooling solution - long hose for track use though LOL!
