Inlet valve seat insert
Hi all by fitting valve inserts and lowering inlet valve out more will I gain more horse power by doing this as my old valves are deep in camber cheers mario.
Re: Inlet valve seat insert
if you have big valves then if you already have exhaust inserts for unleaded there wont be room to fit an insert.
you will gain very little unless fitting the insert allows you a better shape to the short turn or the valves are badly shrouded in the head. if you can it would probably be better to use a slightly bigger inlet .
