Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 81 to 120 of 132
Thread: Project 'squirt my crossflow'
  1. #81
    Spanner Monkey FrEdOoOo's Avatar
    Mar 2009
    Portugal
    384
    25
    Re: Project 'squirt my crossflow'
    Absolutely brilliant!!!
    Fantastic job mate
  2. #82
    May 2009
    Maesteg South Wales
    2,041
    142
    Thats well Impressive mate well done!
  3. #83
    Pit Crew Decade Plus User merp0's Avatar
    Jun 2007
    Chester, Cheshire, United Kingdom
    1,284
    100
    Well done Dave, perhaps you could help me with a 'squirt my Pinto' in the future
  4. #84
    Bodger rvf-boy's Avatar
    Dec 2006
    plymouth
    74
    good job there cant wait to get mine running now
  5. #85
    Nov 2003
    Wirral UK
    6,740
    257
    Thanks for all the positive comments chaps
    Well I took it out for its first drive since the conversion yesterday. It started out badly, the car didn't even have enough power to get out of the workshop!
    The fuel map was ridiculously lean, I had to seriously richen it up to get it to move!
    Since then I've been driving, datalogging and revising the fuel map and it's getting there. Found a bit of a problem, in that I've got the controller set to deliver two squirts of fuel per engine cycle, unfortunately this means that at idle and very low throttle openings it's only opening the injectors for 2 milliseconds or less. This is bad because it takes 1 ms for the injector to open, and also means that even the smallest step changes in injector opening times are relatively large in percentage terms.
    So today I'll have to set it to 1 squirt per engine cycle, which will probably mess up all the table adjustments I made yesterday, but no one said this would be easy
    Ignition wise I've roughed out a map which is basically a copy of a fast road dizzy with vac advance, with a few little tweaks. It seems to be working OK but I won't be messing with it until the rolling road tuning day which I've booked for 5th April.
    Here's a couple of pics of the almost complete setup. Still need to sort out some filters, I might need to swap the trumpets for some smaller diameter ones to give me enough space. I'll need to get a revised strut brace bar made as well.
    http://escort.accelerator.org
  6. #86
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Give me a should it you need some Trumpets...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
    i can get different diameters... Cheaper for TS members.
    I bet you are well happy with the progress
  7. #87
    Nov 2003
    Wirral UK
    6,740
    257
    Thanks Mark, yes I am rather chuffed - not as chuffed as my mate though, when I took it round to his place yesterday the top of his head nearly came off
    Could you send me a PM with what you can get? All the better if they haven't got 'happy racing' etched on them
  8. #88
    Nov 2003
    Wirral UK
    6,740
    257
    On Tuesday I visted AB Garage in Hawarden to set the fuelling and ignition maps up on their rolling road.
    AB advised we go for 13.5:1 AFRs across the board, and 12.5:1 under full power. I'll post the map files later in case they are of use to someone.
    Anyway, the result of all this work is 125bhp at the wheels at 6500 rpm and a car that is much more responsive and enjoyable to drive!
    Factor in 18% drivetrain loss and we're talking about over 145hp at the fly which I'm very happy about
    Here's the graph, ignore the torque figures as the run was done in 3rd gear.
    I just need to knock up a filter now, plans are afoot and parts have been ordered...
  9. #89
    Nov 2003
    Wirral UK
    6,740
    257
    The comparison between carb & dizzy and mapped igntion & fuel injection :
    The carb & dizzy is in the fainter lines.
    You can see that the carb is pretty good in the mid-range, but higher up the RPMs the injected setup pulls ahead. What you can't see is lower down the RPM range the carb wouldn't tolerate WOT at all, hence no line on the graph!
  10. #90
    Nov 2009
    essex
    6,623
    338
    fantastic result if you dont mind asking or you would rather pm me in private, how much do you reckon the whole conversion has cost you?
  11. #91
    Nov 2003
    Wirral UK
    6,740
    257
    Ah... well this might sound like a cop-out, but I couldn't really say for sure!
    I bought the TBs years ago (2007) for another project which never happened, and I really can't remember how much I paid for them. Same goes for the MS.
    The manifold was far more than I anticipated at £300.
    Rough estimate I reckon it's probably been the thick end of a grand to do it all but you could do it for less I reckon if you really tried hard
  12. #92
    25,127
    nice one, 18% transmission losses are prob a bit high though, with a lot more power and massive slicks i only loose 15% on mine, that said its stil a great result, well done
  13. #93
    Nov 2003
    Wirral UK
    6,740
    257
    Thanks Graham
  14. #94
    9,217
    168
    nice result
    and of course you cant quantify drivability.
    what was their view on mapping the ms ? are they used to the ms system ? how long did mapping take ?
    lots of Q's
  15. #95
    Nov 2003
    Wirral UK
    6,740
    257
    Well, the garage was familiar with MS tuning but I actually did the adjustments under their watchful eye.
    It was simply a matter of holding the engine in a particular load cell with the rollers, then adjusting the fuelling till it reached the correct ratio.
    Their approach to setting the ignition timing was a bit less scientific, based mainly on their experience of tuning crossflows in the past.
    We took a bit of advance out in some areas where he thought it was prone to detonate then did a full power run, removed 3 degrees of advance and tried it again. We found that we'd lost power so next we put the 3 degrees back in and added a further 3 degrees of advance, which netted a nice power gain.
    At this stage we had 40 degrees of advance at the top of the rev range and both of us were nervous of adding more, so we decided to pack it in!
    The process took about 3.5 hours in total, including breaks to let the car cool down a bit.
    I must say that I have been very impressed with the Autotune function on megatune, providing you set the o2 targets properly it can produce a pretty good map.
  16. #96
    25,127
    with regards to the timing thats pretty much how you need to do it,
    on the smaller throttle openings you can do the same as you did with the mixture hold the engine under load and adjust the timing to get highest power,
    at the bigger throttles do a power run, add or take out a bit of timing do another power run and lay the graphs on top of each other then you can see exactly where it did or didnt want the advance, adjust the map and go again.
    TBH 40 degrees advance at the very to of an x/flow map doesnt sound scary to me, in fact it sounds right! the thing with management is you will oten see very big adavnce figs because unlike a dizzy you can take advance in and out right through the rev range
  17. #97
    Nov 2009
    essex
    6,623
    338
    makes me want to go fuel injection even more now!!! i'd happily pay that for that result ..... well done fella
  18. #98
    Nov 2003
    Wirral UK
    6,740
    257
    Cheers guys
    Here are the maps as they currently stand
    And here is the current tune (.msq) file
    https://docs.google.com/uc?id=0B6E7k...nload&hl=en_GB
  19. The Following 2 Users Say Thank You to exboyracer For This Useful Post:
  20. #99
    Nov 2003
    Wirral UK
    6,740
    257
    I should probably add that the VE table is for 260cc injectors @ 2 squirts / cycle.
    Also for anyone who tried to download the tune file and failed, it was due to the sharing setting on Google docs - I've set it to 'public' now so it should work!
  21. The Following User Says Thank You to exboyracer For This Useful Post:
  22. #100
    Aug 2006
    Christchurch, New Zealand
    463
    Cheers for posting the map files mate
  23. #101
    Apr 2004
    4,346
    479
    Nice one
    Now get a video of it up so we can all hear how good it sounds!
  24. #102
    Well done fella
  25. #103
    Pit Crew gorilla1q's Avatar
    May 2009
    Cheshire
    1,345
    67
    Top work done there mate I'll be looking out for you (well the car as I don't know what you look like lol) as I live in Ellesmere Port so not too many miles away. Great result with the rollers, Ade is very knowledgeable with the set up and great to have by your side if your punching in the figures. I've used AB garage to tune my rally cars for a few years and he'll always tell you as it is hence my car currently running good safe power (nova rally car)
    Well done
    When I grow up I will have a MK1 Escort
    I must be all growed up now then and paying for it!
  26. #104
    Nov 2003
    Wirral UK
    6,740
    257
    Gorilla1Q, ahhh a local bloke
    I was talking to a fella with a gorgeous white MK1 'tina on black superlites from round your way last year sometime.
    Yeah I've been very impressed with Ade every time I've been to AB, half of me wants to tell the world how good they are but the other half wants to keep them our little secret
    A six week waiting time is enough anyway!
  27. #105
    Mar 2011
    Australia
    58
    That's some great info, thanks heaps for posting your tune! A couple of quick questions -
    Any chance you can post the AFR targets you used for VEAL? I can't seem to find them in the tune you put up
    Is there any reason you've gone for Alpha-N rather than Speed-Density?
    Thanks again and really well done with your setup!
  28. #106
    Mar 2011
    Australia
    58
    Quote Originally Posted by noisymime View Post
    Ignore me, brain wasn't in gear and I'd forgotten you're running ITBs
  29. #107
    May 2009
    Cheshire
    1,345
    67
    Yea I've seen a 'tina a few times this year already sounds like a guy called Mark not had chance to catch up with him for a chat yet! Theres another guy by where a mate has just moved in with 2 mk2 escorts and a mk1 I'll soon be introducing myself to him aswell
    Oh and your secret is safe with me
  30. #108
    Nov 2003
    Wirral UK
    6,740
    257
    The AFR targets were 13.5:1 across the board and 12:1 under WOT.
    Thanks for the compliments everybody
  31. #109
    Nov 2003
    Wirral UK
    6,740
    257
    Still working on this thing!
    I made a big wing baffled sump for the engine as I was suffering a bit from surge last year with the std one
    Onto the biggest headache, trying to get an air filter to fit!
    There was no way I could get a panel filter onto the end of the trumpets due to no.4 being very close to the bulkhead, and even trumpet socks were out.
    So I resorted to a bit of lateral thinking!
    I had to blank off the existing port on the fuel regulator for the pressure gauge as it was in the way, so I drilled and tapped another hole further around
    Add some 45 degree alloy tubing, carefully trimmed to length, and some brackets made up to suit
    The filter base in place, with the air temperature sensor and idle air hose mounted on it
    And the filter case itself in place
    Pretty much all done now
    Clearance from the filter top to the underside of the bonnet is tight!
    I just need to find some short 50mm bore trumpets now to go inside the airbox.
  32. #110
    Aug 2006
    463
    Looking good mate
  33. #111
    Nov 2009
    essex
    6,623
    338
    nice bit of fabrication work thier, looks good
  34. #112
    Nov 2003
    Wirral UK
    6,740
    257
    Just tidying up the loose ends now!
    Firstly, I could not find any trumpets that would really suit my installation, so I resorted to making some myself out of off-cuts from the alloy tubing I made the intakes from.
    I formed the radius for the bellmouths with nothing more fancy than a round headed hammer and a piece of thick wall tubing held in a vice as the hammer form.
    I'm pretty sure they're not the ideal aerodynamic shape but they're better than nothing, I hope!
    I've been struggling with the join between the head and exhaust manifold leaking, due to the size of the ports standard gaskets don't last long at all and exhaust paste has only been a little better. So I decided to try making my own gaskets out of 1.2mm copper sheet.
    Unfortunately, I still had a blow with these new gaskets, so after a bit of thinking I decided to try adding copper rings to both sides of the gaskets to get more of a crush effect. The rings were made from 1mm copper salvaged from a piece of old twin & earth mains cable, held in place with a dab of solder.
    Finally I had to convert the rev counter as the old inductive setup would not work with the megasquirt.
    I bought a cheapo 52mm stepper motor rev counter off ebay and mounted it to the original MK1 tacho's face and rear shell. It's wired to one of the spare outpus on the MS which is configured to act as a tacho output. I can confirm that it works well and is more accurate that the standard tacho ever was!
    Now I'm just waiting on a custom strut brace to be made and it'll be all done
  35. #113
    May 2009
    Maesteg South Wales
    2,041
    142
    Great Job mate fairplay nice tacho mod too..
  36. #114
    25,127
    good thinking on the gaskets and tacho
  37. #115
    Nov 2009
    essex
    6,623
    338
    liking all of that, them trumpets look good and like the genius of the tacho mod, but most of all love the gasket idea, might have to steel that
  38. #116
    9,217
    168
    great thinking link to cheapy tacho please, also what mods are needed to the ms for a tacho o/p ?
  39. #117
    Nov 2003
    Wirral UK
    6,740
    257
    This is the tacho I used
    http://cgi.ebay.co.uk/AUTOGAUGE-CLEA...item53e74d4557
    You'll notice that it reads to 10K rpm, but the MK1 dial is only calibrated to 7k, right? Well if you tell the tacho it's connected to a 3 cylinder engine it reads just about right!
    The mods to the MS are simple enough, it's just a case of using one of the spare outputs - I can't remember which one off the top of my head, but it's listed in the software.
    You just need to add a transistor driver between the output from the ECU and the outside world in exactly the same way as with the fan driver circuit.
  40. #118
    top work on the tacho, I had my mk1 revcounter converted by speedy cables and the MS already had the output setup as i requested this on its build. I still had to mess about a bit by adding a live supply to the ouput with a resistor in but works a treat now.
    More great info here
  41. #119
    Apr 2004
    4,346
    479
    Top Work... But we didnt expect anything less
  42. #120
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Good effort! If you still find you have problems with the gaskets then just use rtv silicone on the head face. I used the copper coloured loctite on mine after the first set of gaskets blew after a week and never had a problem!
  43. The Following User Says Thank You to dangerousdave For This Useful Post:
