Results 1 to 7 of 7
Thread: Hot brake / clutch fluid question
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Hello all,
    How important is it to keep brake and clutch fluid reservoirs cool?
    I'm struggling to find a decent location for my three remote fluid reservoirs. No matter what I try, I can't avoid the clutch reservoir sitting right above the exhaust down pipe - about 5" away. If the fluid heats up here how bad can it be? Or are the temperatures comparable with how hot it would get in the calliper anyway? Maybe I'm worrying about nothing. Any thoughts from you seasoned experts would be appreciated .
    2,659
    268
    Re: Hot brake / clutch fluid question
    Is it not possible to put some sort of little heat shield round them if need be...
    Or wrap the down pipe which can make a big difference to under bonnet temperatures in general, it did on mine years ago anyway...
    Apr 2007
    Chelmsford
    773
    114
    That's a good idea rallyrob. I was going to get my manifold ceramic coated, so maybe the down pipe too. I'm not sure if ceramic coat is as good a heat insulator as wrap. I know wrap would be a lot cheaper though. Still, there'd be quite a bit of heat reaching the reservoir, I guess, as its so close.
    I'm thinking; the fluid probably won't get to more than 250 degree C+? That's what it would take to boil it. How hot can it be 5" away from a turbo down pipe?
    I would go for ceramic coating if your budget allows instead of that awfull wrap stuff that does the metal in the pipe no good whatsoever. Ceramic coating and a heat shield around the reservior and you'll have no problems at all.
    25,118
    if you want the bargain basement fix, go down you local plumbers merchant and get a heat matt for use with a blow lamp, you can use it to shield the hydraulics, plumbers use them when soldering pipes close to walls etc, if they can stand a propane flame directly on them they will cope with heat off an exhaust.
    my e30 race car has one wrapped around the oil cooler pipes to shield them from the exhaust manifold, despite being only an inch away from the exhaust its done a great job.
    i have my fluid pots on the passenger side of both my cars with no issue. If you have them at a decent height they flow fluid to the MC no problem, i actually think the feed pipes go below the MC height at some point but gravity does it work.
    I may stand corrected but how much fluid will get from the pot and end up in the caliper when pressing the pedal there is very little movement of fluid in the system as far as i can tell you only need to push the caliper pistons very slightly for them to work. I would imagine you are more likely to get boiling fluid from the the disk heat if used very hard.
    Did touring cars used to have water cooled brakes ??
    25,118
    your correct on both counts, the amount of fluid moved to work the brakes is very small, and yes touring cars used to (still might i dont know) use water cooled calipers
