Page 1 of 2 1 2 LastLast
Results 1 to 40 of 47
Thread: BIG bump steer issues on my Capri 😞
    boXXer
    Guest
    Hi guys. I’m having bad bump steer problems ok my Capri, mostly when the shocks are on soft for road, so I’m assuming it’s that?
    could you guys take a look at these pics and see what you think?
    the TCA is almost horizontal at normal ride height, and I have spaced the track rod ends down to run almost parallel with the tca.
    When driving along and hitting a bump in the road and blowing through the travel (like 2” probably) it wants to pull the steering wheel out of your hands
    It’s a standard crossmember and standard holes etc.
    boXXer
    Guest
    25,120
    Re: BIG bump steer issues on my Capri 😞
    imho spaced down steering joint is whats causing it, steering and tca may be parallel, but when you take the location of the outer tca ball joint into account, parallel is wrong, id say you need to move the rack down, or move the steering rose joint up
    boXXer
    Guest
    So you reckon I’ve spaced it down too much? Someone on my Facebook has mentioned steering arms could be the wrong way around?
    boXXer
    Guest
    Yup, terry spotted it
    25,120
    if swapping them over moves the steering rose joint up then that should make it better
    3,641
    What wheel offset are those, looks like a geo issue but looking at your where your disc sits in relation to the wheel it looks as though you have a big neg wheel offset which can cause a lot of wander too
    boXXer
    Guest
    Yeah someone else said that. They are -13 15x9
    3,641
    A few years back i had -7 8x15's on my Mk2, had a similar issue that felt like bump steer but with very small susepnsion movements, ie. when hitting small road changes, white lines etc, it was down to too much neg wheel offset, try a little toe in and see what happens.
    boXXer
    Guest
    I really don’t think it’s that. I kinda know what that feels like. Your talking about tramlining, which mine does too 🙄 but, this is deffo bump steer. As it does it as you blow through the travel not really over slight bumps etc.
    3,641
    It was quite severe on my car, not like tramlining when running really low profile tyres. Why not jack the car through it’s suspension travel and measure the bump steer? In my experience really deep negative offset wheels are terrible for steering, a quick toe change would rule that out
    boXXer
    Guest
    Yeah that’s next on my list after I’ve changed the steering arms over 🙄
    Jan 2016
    Hull
    246
    Is there a particular reason why you should use tyre width not suited to the rim?? Looking at the pic the tyre wall is well pulled away from the rim.
    boXXer
    Guest
    Quote Originally Posted by Colr6 View Post
    Because I’m cool
    3,641
    Dont you know, its the stretched look, goes with -50 Neg camber
    boXXer
    Guest
    Exactly that
    Jan 2016
    Hull
    246
    Quote Originally Posted by boXXer View Post
    Because I’m cool
    Bump steer shouldn’t pose any problems then.....lol
  18. The Following User Says Thank You to Colr6 For This Useful Post:
  19. #18
    boXXer
    Guest
    Oh nah, I’m not THAT cool.
  20. #19
    Feb 2012
    United Kingdom
    64
    483
    The job can easily be cured with all correct parts & angles fitted to the car.
    If you prefer stretched tyres on rims (bead leaks likely to happen) & fitting big spacers,big camber etc then forget driving on damp roads anthing more than Miss Daisey would drive like.
    Cool is for the kidz
    Correct angles is for the men.
  21. The Following User Says Thank You to piekey For This Useful Post:
  22. #20
    3,641
    I bet you're fun at parties!
  23. #21
    boXXer
    Guest
  24. #22
    boXXer
    Guest
    Quote Originally Posted by piekey View Post
    You’d deffo hate my Capri then. It’s right chavved up.
  25. #23
    3,641
    Small point - Miss Daisy didnt drive, she was driven, just saying.
  26. The Following User Says Thank You to Erikmex For This Useful Post:
  27. #24
    Mar 2003
    TRURO
    5,250
    246
    Haha chavved up quality.
  28. #25
    boXXer
    Guest
    Quote Originally Posted by meXEco View Post
    😂 rude boi
  29. #26
    Jan 2005
    up north
    670
    and pikeys set up will be the fastest
  30. #27
    Dec 2011
    Cowdenbeath
    400
    32
    Any other pics of Capri
  31. #28
    Mar 2016
    North Wales
    238
    15
    Too much offset, stretched tyres and too much chamber might be classed as "cool" and for straight line, slow cruising ok but if you want to cure your problem there lies your answer.
  32. #29
    3,641
    Thats what i said - see above, but he knows that the issue is bump steer, only way is to jack and measure bump steer
  33. #30
    boXXer
    Guest
    Bump on this. Tried my normal track wheels (15x8 et0) with wider tyres and it does exactly the same thing. Here’s some pics of what it looks like underneath.
    My settings are:
    1mm toe out
    3 deg neg camber
    Not sure on castor, need to get some turn table to measure it.
    It does it a lot more if the shocks are set to soft and it’s blowing through the travel, but my arms don’t look massively out of alignment do they?
  34. #31
    boXXer
    Guest
    Someone above asked for some more pics of it?
  35. #32
    25,120
    My settings are:
    1mm toe out
    3 deg neg camber
    If you have bump steer changing the wheel won’t fix it, although stiffer damping might help reduce its effect. Looking at that pic the whole rack is too high and the steering rod end wants spacing down more.
  36. #33
    boXXer
    Guest
    Thanks graham. I CBA with lowering the rack so might just have to put up with it 😂
    Never had any of this with my old shitbox mk2 🥴
  37. #34
    4,893
    ET-13 wheels give a big scrub radius together with toe-out means you need to hang on to the steering wheel.
  38. #35
    boXXer
    Guest
    So what would you suggest running in terms of toe? And also run et0 wheels?
  39. #36
    Jan 2009
    Germany
    428
    Wrong position of the com struts brackets.
  40. The Following User Says Thank You to Escort TC For This Useful Post:
  41. #37
    boXXer
    Guest
    Quote Originally Posted by Escort TC View Post
    Really?
  42. #38
    Oct 2015
    Essex
    347
    33
    U want 1-2 mm toe in with Rwd
    And pivot points on arms and rack need be same distance apart
  43. #39
    3,242
    Dunno about anyone else but I see no photo's - just image icon's! I'm reading / viewing this on a PC.
  44. #40
    boXXer
    Guest
    Seems to work on Tapatalk but not the web based one. Your not too far from me. I live in chobham.
