Page 3 of 3 FirstFirst 1 2 3
Results 81 to 113 of 113
Thread: Pinto 2.0 water temperature
  1. #81
    Oct 2013
    LTU
    63
    Re: Pinto 2.0 water temperature
    I guess I put it right way as I had some considerations about it. Is this correct?
    Click image for larger version Name:	200705150244425232020070514-12.jpg Views:	257 Size:	130.3 KB ID:	79137
    Now not running turbo because of other reasons
  2. #82
    25,124
    Quote Originally Posted by kliobas View Post
    Attachment 79137
    thats correct way round
  3. #83
    9,210
    Is reading temp from inlet reliable ? It's not really engine temp is it. Why not read water temp
  4. #84
    25,124
    he will still be reading coolant temp, efi pinto has temp sensor in the manifold heater take off
  5. #85
    Oct 2015
    Essex
    347
    33
    My cosy in my mk2 with cosy rad has always sat at 90 deg what ever I do with it
    So 85 prob ok
    Sent from my Bavs iPhone
  6. #86
    Oct 2013
    LTU
    63
    I think I will remove the housing and check, now I'm not sure that it's in correct position. Thanks Graham
  7. #87
    25,124
    if the thermostat is the wrong way round it will open but not until the engines nearly at boiling point
  8. #88
    Oct 2013
    LTU
    63
    Mine has a hole as per recommendation in this topic, so by using bypass it could open earlier if it's wrong way in housing
  9. #89
    Nov 2009
    essex
    6,623
    338
    Having a thought people, I'm running a reasonably powerful turbo pinto (little over 300bhp) and am curious about running water round the back of the block through that bung on the side, i can't quite figure out how to plumb it up though whilst leaving the heater matrix connected and water running to the turbo.
    If im correct, the water comes OUT of the inlet manifold, then into the heater matrix, then into the turbo, then into the water pump. Could i run the coolent out of the turbo into the bung into the side of the block and blank the small water pump connection. Or will doing it this way put more heat into the back of the block as its hot water from the turbo.
  10. #90
    Oct 2013
    LTU
    63
    So the thermostat was put in a correct way ...
    Any other ideas why the temperature is higher than using stock hotter thermostat ?
  11. #91
    Nov 2009
    essex
    6,623
    338
    No one got any idea on this one? I understand i don't think its been done before so trial and error but any advice/thoughts would be appreciated.
  12. #92
    Nov 2004
    Sweden
    1,167
    I have been thinking about something along those lines but never really finished the thoughts.
    General advise here in Sweden with regards to turbo cooling is to plump it so it can self circulate when the engine is off (to aid cool-down). I never did that when I had a water cooled turbo though.
    I would be interested in more brains on this :-)
    Gustaf
  13. #93
    Bodger Frits's Avatar
    Aug 2016
    Netherlands
    86
    If i do not have a heat matrix fitted and blocked the outlet on the manifold and small inlet on the pump. Should there in this case be enough circulation in the cylinderhead when the stat is closed?
  14. #94
    25,124
    Quote Originally Posted by Frits View Post
    there are plenty of pintos plumbed that way
  15. #95
    Aug 2016
    Netherlands
    86
    Ok, and what if i plumb the small outlet on the right side of the Block to the small inlet on the waterpump, would there be still enough circulation in the head? We now Run Without a stat, but enginetemps het high in heavy stages (110deg C ocasionally)
  16. #96
    25,124
    no thermostat at all is a bad idea, the coolant will not circulate around the back of the engine, just remove the middle section from the thermostat, that way there will still be some back pressure in teh cooling system which will force it around teh whole engine rather than just around no 1 cylinder
  17. The Following User Says Thank You to Graham For This Useful Post:
  18. #97
    9,210
    great thread this
  19. #98
    Jan 2004
    South Africa
    3,354
    20
    I actually ran a feed pipe from the waterpump (feed that would go to the heater) to the rear side of the block on a race pinto. Got the idea from Roger Miller here on the forum. There should be a thread about it if u do a search. T
    Think it help here in our hot climate
  20. #99
    Dec 2004
    Papa New Ginea
    67
    12
    Thought I’d post this here as I thing it’s related
    Does any one have any information regarding the normal operating range of air intake temperature on a naturally aspirated pinto? And where it is measured?
    What temperature is best for power? And at what temperature power starts to fall off?
  21. #100
    4,894
    Whilst looking for info on what fanswitch to use I found this sticky.
    Going to fit an alloy rad to my Mk2, the fan-switch Ralloy supplied (M22 type) is a 98/93 (on/off) type.
    Several people commented that they recommend a switch with 85/80 temps or there-abouts; why would Ralloy sell the rad with a 98/93 switch? (haven't aske them yet)
  22. #101
    2,659
    268
    Maybe the Rad itself was sold for a different engine setup rather than a Pinto. A zetec runs closer to that temp so maybe they sell it with the idea of running a zetec.
  23. #102
    4,894
    Engine is BDA and the radiator is for that engine.
  24. #103
    2,659
    268
  25. #104
    3,242
    Higher water temps are becoming normal - fuels, oils and coolants have moved on in 40 years so running hotter (if controlled well) shouldn't cause big issues. BUT cars still equiped with carbs will suffer from high underbonnet temps - its a balancing act . . . . . . 76-80 deg water temps with a constant engine driven fan push air throw the engine bay against 85-95 deg coolant tightly controlled with elec fan and resultant relatively high underbonnet temps due to lack of airflow ? ? ?
  26. #105
    25,124
    hi temps are good for emissions, but max power still requires a relatively cool head which is why most car manufacturers now use electronic thermostats so they can chose between hot for good emissions and economy or cool for max power.
    i see it on the dyno all the time, engine power will go up as you do multiple power runs, it then stabilizes, however if when get to the point it stabilizes you switch off and let it sit for a bit then test again, you will see a power gain, this is because cylinder head temp will of cooled but block will be thoroughly heat-soaked, warm block cool head gives best power.
    with my scrutineers hat on i often watch multiple back to back hub and rolling road power tests, the power always changes every run. which makes me realize with hindsight a lot of rolling road power testing is flawed because results are almost always based on single runs which wont necessarily show up small changes accurately
  27. #106
    3,242
    Not wishing to disagree but I don't see how an electronic thermostat can respond to cool the whole system quick enough to suit max power when someone buries the throttle to, say, overtake a line of cars? IMO the temps may reach optimal power temps after the movement has been completed and max power is no longer required.
    The point you make about head / block temps are entirely valid but in real world scenarios, you can't divorce the two, so surely the third or fourth run in a sequence when temps have levelled out are the 'correct, real world' figures?
    As a biking man you will be aware of Suzuki's oil cooled engines - it is quite often advised to add an additional oil cooler inserted into the head cooling circuit - this blasts oil directly on to the backside of the cylinder around the plug / valves which 'should' be the hottest part of the engine . . . . . whether it achieves a noticable gain, the jury is out unless racing where high constant heat is enevitable!
  28. #107
    25,124
    i was pointing out that you can produce a higher power figure by letting the engine rest a bit after its fully fully warmed up and doing another "pull" but thats not how i test engines.
    i run them until power output has stabilised, then i do a further 5 or 6 pulls and let the software average them, but in practise all the runs will usually be within 1-2 bhp. i also run a water temp mid 80's most of the time so i would say my numbers are pretty indicative of a motor which is being pushed on a track or stage
  29. #108
    3,242
    Fair play !
  30. #109
    May 2004
    Norn Iron
    1,143
    interesting test on water temps....and not as big a change as one would have thought. Different engines may respond in different ways ? maybe, maybe not. And likewise for fuel temperatures, he tested that too, with surprisingly little difference
    https://www.youtube.com/watch?v=q0t29ScyLvw
  31. #110
    25,124
    i like Richard Holdners stuff, the only thing i woudl say is 180 degrees F is only 82C so in my view he didnt really run it particularly hot at all!
  32. #111
    May 2004
    Norn Iron
    1,143
    True, but when he also ran it from much cooler up to that...it still shows it makes a really small difference overall. I would have expected a bigger difference
    Not many people would race an engine at temperatures OEM's run them at though
  33. #112
    25,124
    im not, as Richard said at the end of the video oil temp has a bigger effect.
    ive seen a V8 rover gain 5-6 bhp simply taking the oil from 50 degrees to 70 degrees on same water temp.
    it makes me wonder about some of the small gains we spent hours looking for on the rolling road, was the gain just the oil getting hotter?
    from what ive seen on the dyno, and in the race paddock when power testing cars I can 100% say one pull is defiantly not enough to know for sure if you have a real change
  34. #113
    May 2004
    Norn Iron
    1,143
    If doing a lot of testing, the "variables" like temperatures, would need to be controlled to become more constant. Otherwise as you say, testing could end up all over the place.
