Results 1 to 23 of 23
Thread: Rear wheel on one side has camber
    Oct 2011
    965
    Hi all
    A mate of mine has just bought a mk1 Escort
    its a lovely looking car but I noticed that the wheel one side has quite a bit of negative camber
    Ive looked but can’t see anything untoward
    He’s told me it’s got a decent axle in with LSD and 2 piece shafts
    can someone give any pointers to what it could be
    Re: Rear wheel on one side has camber
    If it has adjustable TCA's then perhaps it just needs adjusted...or worse could be a bent strut, or worse still could be that its had a strut top inner wing repair and the strut top mount is in the wrong place, photos would help.
    Feb 2012
    United Kingdom
    64
    483
    Are you suggesting the car has big negative camber on the rear .?
    Quote Originally Posted by Timsrs View Post
    Hi all
    If it's an English axle there's a fair chance that it could be a bent axle casing, a common problem from a heavy pounding on Rallies.
    2,659
    268
    Quote Originally Posted by piekey View Post
    That's how it reads to me...
    I was thinking it could be a bent casing too.
    Oct 2011
    965
    Yep I was referring to the rear
    Oct 2011
    965
    Do you know if they can be straightened
    Or is it s new axle
    It’s got all brackets and a brace on so he would like to keep if possible
    sorry i thought it was front, is it postive camber, if so sounds like someone has drifted into a kerb, done it myself, when it happened to me it was only the hub flange on the halfshaft that bent,not the axle casing.
    sorry i thought it was front, is it postive camber, if so sounds like someone has drifted into a kerb, done it myself, when it happened to me it was only the hub flange on the halfshaft that bent,not the axle casing. but then obvously youd see postive and neg camber depending on where the wheel is sitting, if its always in one direction then must be the casing.
    Oct 2011
    965
    No
    It’s negative camber so hitting a kerb would give positive
    Unless the halfshaft hub flange is bent and has rotated, have you moved the car to see if the camber angle goes from neg to pos? if not then youre looking at a bent axle.
    Oct 2011
    965
    No
    It always stays negative
    Wheel doesn’t wobble at all
    Bent axle it is then
    Oct 2011
    965
    Can they be straightened???
    2,659
    268
    I've seen an Atlas straightened, you didn't say whether it's an Atlas or English.
    Any axle can be straightened with heating and careful measurement but for the price you’ll pick up a new axle casing I’d just replace. I bought a good Mk1 casing for £50 just a few months ago.
    Oct 2011
    965
    Quote Originally Posted by rallyrob View Post
    Its an English axle
    Its an English axle
    As Erik says pick up another casing if you can find one. They do seem to be getting in short supply now as the F2 Stock Cars use them.
    If you go down the route of straightening it you'll need to find where abouts its bent and then make a jig to hold it in. When we used the English axle for Road Rallies we never bothered straightening them when they got bent as the axles were never in short supply.
    there is a way to straighten it still on the car! you can do it with a big bead of weld, run a big bead of weld around the bottom 3rd of the axle, the weld will contract and straighten it, of course its a bit hit and miss, too much weld and you will have positive camber. ive even seen axles where toe has been corrected like that
    3,242
    Ingenious - Very ghetto / Red neck solution, but if it works!
    Oct 2011
    965
    Thanks Graham
    can you be more specific of where to put the bead of weld
    Not quite sure where you mean
    I think it’s something we’ll try
    That would depend on where and how much its bent, you would have to measure it....you can achieve the same thing but just applying heat without welding.
    The best way would be to make a jig measuring distances between the top and bottom of the halfshaft flange across the width of the axle, then heat slowly in the area you need to contract keeping close eye on the measurement changing, then allow to cool slowly repeating the process untill you get the correct measurement, in my opinion welding would introduce too much localised heat and have less control.
