Hi all im fitting ARP studs to my pinto, couple of questions do i lightly nip the studs in the block?
Also how do you do the back two as the nuts sit to deep in the head to get a socket on?
no need to nip them but you can if you want.
ive fitted loads and never had a problem with the nuts being too deep for a socket
ARP usually provide torque figures but will depend on whether you are using ARP nuts or std, ARP lubed threads or dry - all will affect the required figures . . . . . not very helpful Huh!
use arp lube on the treads and 80lbft
