Results 1 to 15 of 15
Thread: Help needed with my twin choke webbers on my Ford V6 essex in the Stag
    Tyre Kicker andy007007's Avatar
    Sep 2011
    dorset
    Question Help needed with my twin choke webbers on my Ford V6 essex in the Stag
    Hi.
    I have tried loads, if I go along the car is ok-ish ! When you come to stop, at lights, etc then pull away the car dies for a second or two, you have to rev more and it smokes slightly and goes, any ideas?
    Sep 2011
    dorset
    Re: Help needed with my twin choke webbers on my Ford V6 essex in the Stag
    Someone from http://www.fastroadcars.co.uk/ just gave me some advice, that part seems ok now, just cut the pipe and blanked it off for the anti stall device, workd great. Just have the 'hunting' ? now when I do constant speeds, worse at 30mph!
    Sep 2011
    dorset
    Put the next size up in the jets, .05 now, works tons better
    World Champion Decade Plus User RETRO_AL's Avatar
    skipton
    4,845
    18
    Sounds like it was running a bit rich?
    Sep 2011
    dorset
    I thought bigger jets puts more fuel in and makes it richer?
    Apr 2007
    East Yorkshire
    They would, just check the carb isn't sucking air via worn throttle spindle or base gasket, bigger jets could possibly mask the problem. What settings are the idle mixture screws before and after?
    Sep 2011
    dorset
    I have a new base gasket and while the engine was running I just spayed wd40 then carb cleaner around the body and the engine didn't change a note at all, not sure how to test it properly? The idle screws are about 3 turns out. Before I have no idea.
    Oct 2011
    Bridgend
    66
    9
    Check the power valve screw ,also check accelerator pump diaphragm along with accelerator pump jet.
    I take it is a 38 DGAS
    Sep 2011
    dorset
    It is a 38dgas. I'm not to up on them, where are those parts?
    Sep 2011
    dorset
    just found my old post as car smokes a little on idle more, need more help!
    9,213
    168
    Valve stem seals maybe ? Do you get a cloud when you start in morning ?
    25,124
    smoke isnt normally a carb issue unless it black
    Sep 2011
    dorset
    a little, but mainly once car is hot
    9,213
    168
    when you pull away after stopping at lights ? thats usually a sign of worn guide seals too.
    Sep 2011
    dorset
    going along is ok and it runs nice, once stopped at lights it smokes under idle
Tags for this Thread
