Having trouble fitting my Gaz inserts into my RS legs, taken the old dampers out no problem but the insert doesn't fit down the leg and even if it did fit, how would it be secured in place?? They came with a large threaded retaining nut but there is no thread within the damper leg to screw into??
Code on the insert is GAI 4103 which does seem to be the right one.
Help please!!!
