Results 1 to 4 of 4
Thread: Engine mount rubber thickness?
    Apr 2020
    Braintree
    I’m making my own mounts for a blacktop to fit an escort crossmember, I’ve searched and read loads of posts but can’t seem to find what thickness the rubber engine mounts have to be to clear the rack and for the engine to sit straight?
    Are they both 50mm or is one side 50mm and the other 35mm?
    thanks
    25,124
    Re: Engine mount rubber thickness?
    surely if you are making your own mounts you make them to suit whatever rubbers mounts you have? dont forget because they sit at an angle the different thicknesses dont change the height of the engine by that much
    Apr 2020
    Braintree
    Yes although I’m making my own, I just figured that there was an optimal thickens to use? I’ve ordered a pair of 50mm now ����
    Dec 2011
    Cowdenbeath
    400
    32
    Mine uses 50mm either side
  5. The Following User Says Thank You to Turboman For This Useful Post:
