1.6 turning by hand results in lower pulley slipping
Hi guys, hope you can help me out. I've recently had the head off (1.6) to fix snapped exhaust stud. Put it all back together and when I try and turn by hand in lower pulley it will turn and then feels like it slips and the cam pulley and dizzy do not turn. I'm turning clockwise, this doesn't happen when turning anti clockwise. This results in the static timing going out of alignment. When this happens the cam belt doesn't move the belt is tensioned. Someone suggested Woodruff key maybe missing from pulley. They also suggested that it was highly likely the valves would now be bent. It hasn't started in this state just turned over on starter.Any suggestions would be greatly appreciated.
Thanks, Dave
Re: 1.6 turning by hand results in lower pulley slipping
Woodruff key is a possibility - did you remove the pulley - if not, then it is unlikely! Could be the aux drive pulley which drive the oil pump and dizzy ?
The Pinto is a NON interference design which means the valves shouldn't clatter the valves with a stock cam! Is the tensioner secured and actually tensioning the belt?
Hi, cheers for the reply. It's a standard 1.6 apart from 2.0 cam. The belt is tensioned up. I did take the crank pulley off when fitting the belt back. I haven't checked the other pulley though. What should I look for specifically?
Thanks for the help. Dave
Search me - my pinto knowledge extends to removing one and replacing with a Zetec and fixing a snapped cam belt beside the kerb when I was a LOT younger!
sounds like you have lost the woodruff key, 1.6 pintos can suffer valve piston contact due to the shallower combustion chamber, especially with a 2.0 cam fitted, but its unlikey you have bent any valves unless you have forced it to turn
Sorry - I forgot about 1.6 Pinto DOH! My 2.0L is scant!
Thanks guys,
Fingers crossed there's no bent valves. Is fitting a Woodruff an easy operation? If it turns out to be this.
should be easy but the first thing is to find it ? this is what your looking for - it fits in a slot in nose of crank and pulley is grooved to slide over it.
https://www.burtonpower.com/woodruff...nto-ft585.html
if you take bottom pulley bolt out and turn via pulley or cam sprocket then if its slipping you should be able to see/ feel end of crank not moving ? (or flywheel ring gear)
Sorry to be the harbinger of doom but the 1.6 pinto engine is an “interference” type. After many years working at Dougherty’s Ford in Runcorn I can guarantee that you would have bent at least one valve when cranking on the starter if the valve timing is incorrect. If the woodruff key had gone awol but the crank pulley was tightened to the correct torque and the valve timing correct you may have got away with it (tho I doubt that), but if you can make the crank pulley “slip” by turning it by hand I don’t hold out much hope. The starter motor turning torque is more than enough to bend a valve.
I have had 1.6 Pinto’s turn up where the timing belt has failed at idle and the customer himself fitted a new belt (weekend Haynes technician) but then experienced a constant misfire, tho starting ok & believing/appearing to have decent compression: this is a slightly bent valve issue.
Best of luck.
