Originally Posted by
mrmk2 Ok, got her out on the road today and here is what I found. Idles ok, but does not like it when I accelrate. It splutters an blow back in the carb. But I drowe her hot and started checking. Ignition was a little high so I adjusted it down to 13 deg whith vac off and blanked. It does not advance as much as I would like, about 30 degrees. Checked all sparkplugs, and found them to be white, too white for what I like. Nothing near the brownish I would like. BUT. On cylinder 2 it was all sooted so I expect it has'nt fired properly here. Could be nothing, because it has only been started and rolled out of the garage several times and not been driven warm for quite some time so if it starts to soot it will just be worse I expect. Back to the white sparkplugs, it seem lean but I think the jets certanly are big enough so I would expect them all to be black. I think I need to order a rebuildkit and some more jets. And check that dizzy. And checked for false air with brakecleaner and found nothing wrong.
Regards
