hi guys, ive got my duratec running, but its over heating. Ive removed the thermostat and heated it in boiling water, it opens so cant be that. Its plumbed as follows, the rear outlet comes over the exhaust into the top of the rad, the bottom of the rad goes into the thermostat. The smaller outlet on the thermostat is blanked off. The return above the thermostat is going to the back of the cylinder head as per original. My radiator is stone cold, i checked the water pump when i built the engine and seemed fine. Im using a radiator like a mk1 escort, with the filler neck built into the top. Could i have an air lock? ive run the engine with the cap off to try to lose air if there is any.
Adam
