Originally Posted by
cormonov Thank you Katana and Wildo for your comments, the aforementioned is correct, in the case of my escort the space for 8J wheel in rear is fine both towards the side of the arch (Gr4 arch) and the rear shock absorber. the shaft is an Atlas as you can see in the photograph. My doubt is precisely that although the edge of the front tire is aligned to the rear, obviously as the rear is wider, the rear track ends up being smaller. My car is a tarmac rally car so the tires I use are semi-slick. In track configuration, cars tend to show the wider rear tires in a much more visible way vs. the front ones, showing a different track width (if more wide wheels at rear and external border is aligned with the front wheel the resulting track is lower at rear vs the front) . As far as I understand the elements of suspension geometry take into account the track widths over the width of the tire. This is the source of my confusion.
