Results 1 to 8 of 8
Thread: interesting vid on facebook. IKE Engineering
    Mar 2009
    sussex
    148
    25,124
    Re: interesting vid on facebook. IKE Engineering
    85 cfm would of been a standard port, an average nothing special big valve head (most are wrong shape) will flow 105cfm, 120 cfm is a good flowing big valve, a really good one will flow 125ish cfm all these numbers @10" depression.
    2,659
    268
    That's interesting, not that I really understand it. But The super flow gauge showed 117cfm but on his laptop it showed
    122cfm. So which is it? And also does it matter what cam is in it, as to valve lift affecting flow?
    2,659
    268
    Also really liked the video under that one re: The accuspark Xflow competition dizzy, being tested by Bestek.
    25,124
    his laptop was probably had a correction factor for temperature and humidity.
    regarding the cam yes and no, you should consider the cam, no point having a head with really good flow at a valve lift way beyond where the cam goes, especially if the flow suffers at lower lifts. you also need t bear in mind a valve is only at full lift for a moment. but its at mid lift twice
  6. The Following User Says Thank You to Graham For This Useful Post:
  7. #6
    4,893
    If you look at the cam of a camshaft (especially a std-ish cam) the duration of a valve at or near max lift is actually quite long. Whereas it will fly past mid lift (half lift) quite fast.
  8. The Following 2 Users Say Thank You to Miniliteman For This Useful Post:
  9. #7
    Jun 2015
    Australia
    295
    Good point miniliteman mid lift is good but valve lift from 300 to 500 inch lift is more important I've try different heads and my motor made more power with more upper lift flow cheers mario.
  10. #8
    Dec 2004
    Ireland
    1,781
    31
    Something to consider
    Multiply the lift by the flow at that lift and graph the result plotted against the cam duration on the x axis. The one with the biggest area under the resulting curve should theoretically have the most flow overall and power. There are probably other considerations such as the momentum of the air flow, swirl etc.
