Results 1 to 5 of 5
Thread: Duratec Oil for boot mounted Dry Sump
    Jun 2004
    Bristol
    1,494
    18
    I'm fitting a Duratec to replace the N/A cossie, keeping the existing Dry Sump system and the tank in the boot
    I've used Valvoline VR1 20w50 for many years, but I assume I should be using a more modern oil for the Duratec
    Any suggestions / experiences?
    I remember being told many years ago that a fully synthetic oil would cause problems with a boot mounted tank as the pump would have difficulty sucking it through to the engine
    But I'm not sure if this is an issue
    Gavin
    25,124
    Re: Duratec Oil for boot mounted Dry Sump
    Quote Originally Posted by GavinR View Post
    Gavin
    i cant see any reason why a synthetic oil should be any different to a mineral, or a semi synthetic.
    a thinner oil should be easier for the pump to suck through anyway
    I have just got some oil for my duratec from my mates car parts shop and it is specific for a duratec and zetec. Not sure why but there must be some magic in it !!!
  5. #4
    25,124
    lots of oils are engine specfic, but often thats down to exhaust emissions, believe it or not you can find the same engine in a Peugeot and ford but using different oils!
  6. #5
    Jan 2011
    norway,west
    160
    It often has to do with the exhaust after treatment. Ford uses one DPF ore cat, and Peugeot uses another one.
