Pinto inlet port
When porting a pinto inlet port what size do you make the bowl area of the port I know throat area is 90% of the valve what percent do we make the bowl area help needed cheers mario.
Re: Pinto inlet port
Does anybody know what size an injection pinto inlet port size is cheers mario
about 3mm bigger than a carb one, but all heads seem to vary a bit.
the port also gets wider where meets the bowl
