Wanted to share this info, just to show again you don't need 38DGAS so fast. I was selecting the carburetor for my MX5 1800 Turbo engine. The carburetor for a turbo engine does not need to be any bigger as the one that give you max power in NA form. So I fitted the original MX5 exhaust manifold and tested both 32/36DGAV against a 38DGAS with 2mm enlarged chokes (the standard 38DGAS chokes are almost the same size as the one fitted to 32/36DGAV). This "enlarged" 38DGAS is some kind of a stock version I use for larger V6 engines or small V8's. On a Stag V8 the enlarged version makes 10-15 Bhp more power.
As can been seen in the graph, both carbs made the same max power.
Both carburetors made a dip round 2500-3000 RPM. Caused by a slightly rich mixture but because I was only interested in the max power potential I did not made any mods to the carbs to correct it.
This time I was surprised how well the 38DGAS was reacting at the throttle compared to other test work I did with this carb on other engines, despite the rich spot at full load round 2500-3000 RPM (which I could easy fix if I wanted) the mixture was very good overal. Only at the point I added the turbo the tuning advances of the progressive 32/36DGAV became more and more clear.
